I am planning to install Openembedded/Qt5 for T20 on a Opensuse Linux 3.12.62 notebook.
It is not clear if a Systemd controller container is required or not.
Thank you for your attention.
Miguelon.
Hi Miguelon
I assume you are using openSUSE 13.1 and with the systemd controller you refer to the lightweight systemd container setup .
This lightweight systemd containers are required for very new distros with toolchains not suitable for the oe-build. For the rather old openSUSE 13.1 this is not needed.
Max
