Here is the output of the debugger if I power up the system from scratch with the debugger enabled:
Toradex Bootloader 2.0 for Tegra Built Mar 6 2017
Press [SPACE] to enter Bootloader Menu
Colibri T20 512MB IT V1.2A SerialNo: 4755477
RAM: 512 MB, CarveOut: 64 MB
Locating kernel image in flash…Ecc.Corrected(1) Blk 110 PgOffset 0, status: 0x100100
Done(1356)
Decompressing IMAGE(25895437, 50612212) from FLASH(0) to RAM(16000)…Done(569ms)
Jumping to image at 0x80016000…
Toradex Windows CE 7.0 IMAGE 2.0 for Tegra Built Feb 6 2017
INFO:OALLogSetZones: dpCurSettings.ulZoneMask: 0xb
L2 cache enabled
MainMemoryEndAddress adjusted from 0x86000000 to 0x9C000000
Main Phys Mem: 0x00000000:0x1BFFFFFF
Carveout Phys: 0x1C000000:0x1FFFFFFF
Cold boot selected
Chip Id: 0x20 (Handheld SOC) Major: 0x1 Minor: 0x4 SKU: 0x8
NVRM Initialized shmoo database
PllClocks(Mhz): X=1000, M=666, C=581, P=216, A=24.576
SysClocks(Mhz): CPU=1000, AVP=232, SysBus=232, Mem=333, EMem=666
GraphicClocks(Mhz): Host=108, 3D=111, 2D=111, Epp=111, Mpe=111, Vde=232
Loading FlashFileSystem(NAND)…
Micron M71M PS:4KB BS:256KB DS:1024MB BCH16 ECC
INFO: TotalBlocks = 4096, FreeBlocks = 179
BBs: 0
No TAT bad block found.
No TT bad block found.
Done FlashFileSystem(NAND)(106)
Loading Audio…Done
Loading Serial2(UART_B)…Done Serial2(0)
Loading Serial3(UART_C)…Done Serial3(0)
Loading SDIO(SDIO4)…Done(4)
Loading USBFunction(Port1)…Done
Loading USBHost(Port2)…NvDdkSdioSetClockFrequency: Requested: 100 KHz, Actual: 101 KHz
Done
Loading USBHost(Port3)…Done
NvDdkSdioSetClockFrequency: Requested: 25000 KHz, Actual: 25411 KHz
NvDdkSdioSetClockFrequency: Requested: 50000 KHz, Actual: 48000 KHz
Loading DisplayDriver…Done(73)
Set LCD to 800x600 (60Hz)
Loading Keyboard/MouseDriver…Done
Loading TouchDriver…Maximum Allowed Error 5:
RTC Time restored (23.05.2017 17:01:04)
AX88772B: instantiate [AX88772B1]
Loading NETUI…
Done NETUI
Done
Ecc.Corrected(1) Blk 689 PgOffset 46, status: 0x800108
Ecc.Corrected(1) Blk 694 PgOffset 41, status: 0x20010f
Ecc.Corrected(1) Blk 695 PgOffset 10, status: 0x20108
Ecc.Corrected(1) Blk 701 PgOffset 24, status: 0x1010b
Ecc.Corrected(1) Blk 713 PgOffset 49, status: 0x800103
Ecc.Corrected(1) Blk 714 PgOffset 48, status: 0x4010d
Ecc.Corrected(1) Blk 714 PgOffset 60, status: 0x80106
Ecc.Corrected(1) Blk 719 PgOffset 10, status: 0x10100
Ecc.Corrected(1) Blk 721 PgOffset 36, status: 0x100106
Ecc.Corrected(1) Blk 722 PgOffset 60, status: 0x20109
Ecc.Corrected(1) Blk 729 PgOffset 36, status: 0x10106
Ecc.Corrected(1) Blk 730 PgOffset 41, status: 0x1010b
Ecc.Corrected(1) Blk 731 PgOffset 3, status: 0x80103
Ecc.Corrected(1) Blk 731 PgOffset 13, status: 0x80103
Ecc.Corrected(1) Blk 667 PgOffset 60, status: 0x40101
Ecc.Corrected(1) Blk 742 PgOffset 2, status: 0x800102
Ecc.Corrected(1) Blk 742 PgOffset 5, status: 0x20105
Ecc.Corrected(1) Blk 764 PgOffset 2, status: 0x40100
Ecc.Corrected(1) Blk 763 PgOffset 59, status: 0x400100
Warning: you are requesting IOCTL_HAL_GET_DEVICE_INFO::SPI_GETPLATFORMTYPE, which has been deprecated. Use IOCTL_HAL_GET_DEVICE_INFO::SPI_GETPLATFORMNAME instead.
Loading NETUI…
Done NETUI
Ecc.Corrected(1) Blk 761 PgOffset 39, status: 0x400100
Ecc.Corrected(1) Blk 761 PgOffset 48, status: 0x800100
Ecc.Corrected(1) Blk 754 PgOffset 10, status: 0x400100
Ecc.Corrected(1) Blk 754 PgOffset 56, status: 0x80100
Ecc.Corrected(1) Blk 759 PgOffset 46, status: 0x10100
Loading NETUI…
Done NETUI
Ecc.Corrected(1) Blk 752 PgOffset 60, status: 0x100100
Ecc.Corrected(1) Blk 750 PgOffset 55, status: 0x20100
Ecc.Corrected(1) Blk 751 PgOffset 3, status: 0x10100
Ecc.Corrected(1) Blk 756 PgOffset 55, status: 0x20100
ramstc.exeErrorAn unexpected error has occurred in ramstc.exe.
Select Quit and then restart this program, or select Details for more information.
An error message cannot be displayed because an optional resource assembly containing it cannot be found
ramstc.exeErrorramstc.exe
InvalidOperationException
The crash is caused because the system wants to use the debug serial port.
So I created a debug version of the code and ran the system from the USB debugger with modified code so it wouldn’t crash trying to use Serialport1. This is the output I got:
Loading NETUI…
Done NETUI
Loading NETUI…
Done NETUI
The system then displayed the previously described NotSupportedException.
I am running the request to show you guys the code up the chain of command here - but even if it is approved I don’t know what portion of the code is causing this error (I know the generic function, but it is over a thousand of lines of code). As I said before, the particular line that the system crashes on moves and each one I have seen so far is a valid line of code.
I am loading a fair amount of information into relatively large arrays (1-84 by 1-360) but even the largest ones shouldn’t be more than half a MB. Yet the problem seems very linked to the size of the files so I’m not sure where the problem could be caused…
I will try calling today to work out next steps, but would welcome any suggestions you might have.
