When udating to the 2.1 library i have noticed that the sysinfo no longer works. I have changed my code to match the demos and still experience the same problem. When calling
printf("\tBspVersion\t= ");
ret = Sys_GetConfigInt(hSys, L"BspVersion", &BspVersion.Val);
I get the error saying it hit a break point. I will try to get more information but i went back to the old libraries to check it was fine before and now i can’t get it to run at all with new libraries. It doesn’t get into my code. I just thought i would see if you had the same issue.
I am using visual studio 2015
