Hello sir,
I was reflashing imx6 colibri with win ce8, but after successful reflashing the Flash disk not showing System folder and only showing Windows folder and .exe files are also not executing.
Help me too solve this problem.
Thank you in advance.
If you reflash a module you loose the FlashDisk content. System folder is not there by default. Most often it is added if you use one of our installers or added it manually before.
As your exe is not working, you probably are missing some dlls in the system folder. Could it be you want to use a .NET application but you have not yet installed .NET Framework?. You get the installer here.
