Switch from tdx-wayland to torizoncore on Apalis imx8
Working on Apalis imx8 with Ixora V1.2A board.
I installed the Toradex Embedded Linux Reference Multimedia Image while setting up but later came across TorizonCore.
I want to run Docker on the SoM, and want to have the recommended TorizonCore with evaluation containers on the board. How can I switch?
I don’t really have any experience in this domain and any guidance would be appreciated.
Hi @sdass ,
Thanks for using the community and welcome :slight_smile:
So the easiest way to got here is to recover the module and install TorizonCore with the evaluation containers directly through Toradex Easy Installer.
Recover the Module:
And then install Toradex Easy Installer:
Then from there, you can choose the TorizonCore with eval containers as the image to be flashed onto the module.
For more information about anything Torizon related I recommend having a look here:
Kevin
Thanks for the prompt and detailed response!
