thanks for the reply. Aftre these changes i don’t have new logs, but the exactly the same error. When the error occurs, the state of the SDA and SCL signals is as follows:
SDA->Blue signal
SCL->Pink signal
If I keep pressing the capacitive touch, the signals do not change state and remain as in the image
Thank you for your measurements and the information.
This does seem to be rather strange behaviour. The controller seems to block the bus by pulling SDA down to 0. Unfortunately the measurements might not be telling the whole story. What might be of value, would be the knowledge of what happens during the final 20 clocks. For that to be captured you could try using the trigger mode normal and then to trigger on negative edge. Alternatively you could use a logicanalyser to get a visual of what data is being transmitted on the bus. We are still assuming that the controller is missing a clock cycle.
However, the kernel should be initiating a recovery, which does not appear to happen. It might also be interesting to see what happens on the bus, when it is blocked and the following command is being sent:
i2cdetect -r -y 1
Would the SCL line then toggle?
In essence the following two measurements could be interesting:
The last 20 clock cycles before the bus is blocked.
measurement, when the bus is blocked and you try accessing the bus.
thanks for the reply. I have a littele uptade regarding your question. When the issue occurs and the capacitive touch no longer responds, the following error messages are continuously printed:
Every time I touch the capacitive touchscreen, the counter increments. I observed that when the issue occurs, the interrupt counter of the capacitive touchscreen increases autonomously, even without any touch input.
Sorry, the interrupt counter increases due to a device tree (DTS) configuration error. I changed IRQ_TYPE_LEVEL_LOW to IRQ_TYPE_EDGE_FALLING. However, the issue has not been resolved.
Looking at the I2C bus that interacts with the touch controller and seeing what communication happened just before the device gets stuck would be useful.
It would also be important to check the GPIOs connected to the touch controller, what happens to them when this issue manifests.
