Stuck after trying to use iMX6 with Iris carrier board and capacitive display
I’m trying to use the capacitive touch display with an iMX6 module and Iris carrier board. Everything was working fine using the tutorial, but when I entered the following commands to enable touch it start giving me an error (see below).
setenv fdt_fixup 'fdt addr ${fdt_addr_r} && fdt set /soc/aips-bus@02100000/i2c@021a8000/atmel_mxt_ts@4a status okay'
    saveenv
I followed the instructions to recover the Easy Installer (which worked fine) but I’m still getting the same errors. How can I recover the iMX6 and prevent this error going forward? Any help would be appreciated. Thanks.
U-Boot 2016.11-2.7.4+g1b121c6 (Oct 04 2017 - 22:18:20 +0000)
CPU:   Freescale i.MX6DL rev1.3 at 792 MHz
Reset cause: WDOG
I2C:   ready
DRAM:  512 MiB
PMIC:  device id: 0x10, revision id: 0x21, programmed
MMC:   FSL_SDHC: 0, FSL_SDHC: 1
auto-detected panel HDMI
Display: HDMI (1024x768)
In:    serial
Out:   serial
Err:   serial
Model: Toradex Colibri iMX6 DualLite 512MB V1.1A, Serial# 05129146
Net:   using PHY at 0
FEC [PRIME]
Booting from internal eMMC chip...
reading imx6dl-colibri-eval-v3.dtb
45508 bytes read in 18 ms (2.4 MiB/s)
reading uImage
4963928 bytes read in 185 ms (25.6 MiB/s)
libfdt fdt_path_offset() returned FDT_ERR_NOTFOUND
emmcboot failed
MMC: no card present
starting USB...
USB0:   Port not available.
USB1:   USB EHCI 1.00
scanning bus 1 for devices... cannot reset port 3!?
cannot reset port 4!?
4 USB Device(s) found
       scanning usb for storage devices... 0 Storage Device(s) found
       scanning usb for ethernet devices... 0 Ethernet Device(s) found
USB device 0: unknown device
BOOTP broadcast 1
DHCP client bound to address 10.10.10.45 (271 ms)
Using FEC device
TFTP from server 10.10.10.1; our IP address is 10.10.10.45
Filename 'boot.scr.uimg'.
Load address: 0x17000000
Loading: T T T T T T T T
Abort
Could you please do
Colibri iMX6 # env default -a
Colibri iMX6 # saveenv
Thank you!
You are welcome.
