Stpes to commit our patch for kernel 4.4.88 for Vf61
Hello Everyone;
As per our End application Goal, we developed/merge the “gpio-line-names” functionality in kernel 4.4.88.
can we upload that patch on “Toradex git repository”?
Thanks & Best Regards;
Nikunj Patel
hi @nikunjp26
Welcome to the Toradex Community!!!
Could you provide the hardware version of your module?
Who are “we”? Which company are you working for? Which changes have you exactly done? Are these changes for everyone or just only for you? Could you share these changes?
Thanks and best regards, Jaski
Dear Jaski,
Thanks for your reply.
Q. Which company are you working for?
Ans. I am working for the “System Level Solutions” Company. you can refer below link.
http://www.slscorp.com/
Q.Which changes have you exactly done?
Ans. We have added “gpio-line-names” support in gpio sysfs support in place of the traditionally gpioxx number.
Q. Are these changes for everyone or just only for you?
Ans. yes for everyone can use this.
Q. Could you share these changes?
Ans. yes please find a link text attached patch. This patch is just for reference not final.
Dear Nikunj,
Thanks for the patch. We try to keep our BSP aligned to upstream Linux if possible. That means we try to avoid using/implement custom functionality unless accepted by the upstream community. This makes sure that we do not diverge from what is typically expected from a Linux BSP and avoid fragmentation.
There seem to have been previous attempts to add names to GPIOs upstream, e.g.:
http://lists.infradead.org/pipermail/linux-arm-kernel/2015-July/357418.html
Unfortunately, it seems not to have make it into the kernel yet (the patchset did not get merged)…
For Toradex it would be interesting if GPIOs could be accessed using their SODIMM number even. There is libsoc, a user space library which allows to access GPIOs using C (Python bindings are available) and allows board level abstractions. Some of our modules are support already :
Hello stefan,
support already :
https://github.com/jackmitch/libsoc/tree/master/contrib/board_files
As per your above reply we can provide you the patch for vf61 so “GPIOs could be accessed using their SODIMM”.
Nikunj Patel
How would this patch look like? What is better in your solution compared to the solution with libsoc?
Hello Stefan,
gentle reminder,
Nikunj Patel
Hi @nikunjp26,
Thanks for your patch. As we already wrote, for us there is a working solution with libsoc. We don’t want to apply your GPIOs patch.
Best regards, Jaski
OK…
Thanks for your valuable time and reply…
Best regards;
Nikunj Patel
You are welcome.
