Start with one cpu
Hi Folks!
Someone knows how to boot a dual core Colibri iMX6 with just one cpu ?
Thank you
When module boots it using only one core. Second core got enabled by Linux when it’s loaded.
Could you specify your goals? Why do you need only one core to be used?
I have to try the behaviour of a multithreaded application with one core vs. two cores. Setting the cpu affinity isn’t the solution.
Found it! : article
Perfect. Thanks for your Input.
