Standoff height for Verdin module
On our carrier board for the Verdin iMX8M module we use a SODIMM edge connector with 8mm connector height. For this connector the Carrier Board Design Guide mentions a Board-to-board distance of 5.42mm. We want use Wuerth Elektronik WA-SMSI SMT Steel Spacer as standoff under the module.
Unfortunately the Wuerth Spacer are only available in 5.0mm and 5.5mm length. Which length do you recommend? Or is there any alternative supplier that fits better?
For an 8mm SODIMM connector with a board-to-board distance of 5.42mm, you have two standoff options available from Würth Elektronik(1)(2):
Standoff Height Recommendations
Based on the Verdin module fixation requirements, the standoffs underneath the module (S1 and S2) should ideally be 2.5mm tall for a final product(3)(2). However, Toradex carrier boards use 2mm tall standoffs for easier module insertion during development(3)(2).
For your 8mm connector setup:
  • 5.0mm length would be closer to the recommended 2.5mm + board thickness
  • 5.5mm length might be too tall and could create alignment issues
Recommendation
I recommend using the 5.0mm Würth spacers as they will be closer to the intended standoff height for production use(3)(2). The 5.5mm option may push the module too far from the carrier board and create mechanical stress on the SODIMM connector.
Important Considerations
The standoffs S1 and S2 are positioned below the longer edge of the module (further from the SODIMM DDR4 connector)(3)(2). Using 2.5mm standoffs (or close to it) ensures parallel alignment of the module and carrier board PCBs, especially if you plan to mount a heatsink(3)(2).
If you need additional standoffs (S3 and S4) for mounting the Verdin Industrial Heatsink, those would need to be 7.0mm tall(4)(2).
Hello @CTelgmann
You could compare our connector height with your connector height and adjust spacer size accordingly.
Important note: For the spacers that are not underneath the SoM, the heatsink needs to be compatible with them.
If you for example take a look at the Boom of our Dahlia Carrier Board | Toradex Developer Center
you can see we use:
  • Round Standoff M2x0.4 (7.00mm) - 9774070243R
  • Spacer 2.5mm M2 - 9774025243R (under SoM)
you can use also other carrier as example. just refer to the BOM files on the developer site
hope this helps
thank you & best regards
