Dear @henrique.tx , I’m totally agree with you, I prefer to use the panel driver, instead of staging driver.
But I have to do it step by step. Because the only driver that works for me is “staging” driver in kernel 4.9 (AS MODULE) I started from it. As I wrote here:
now I’m able to have the driver integrated into kernel 4.9 (NOT as a module) and I have the splash screen. This is the first step.
Then I passed to kernel 5.4, and I tried to do the same (with “staging” driver, and the same device tree like in kernel 4.9). The strange thing is that the /dev/fb0 interface is correctly setup, but it doesn’t work (also with a simple “cat /dev/urandom > /dev/fb0”). This is quite surprising for me.
So I cut off “staging” driver and I tried with “panel” driver under drm. For this I enable “Direct Rendering Manager” in “Graphic support” under “Device Drivers”, and then “Sitronix ST7789V panel” under “Display Panels”.
Then I use this devicetree for this:
&iomuxc {
pinctrl_disp_gpio: disp_gpio_muxgrp {
fsl,pins = <
MX7D_PAD_ECSPI2_SS0__GPIO4_IO23 0x14 // DIS_RST @ SODIMM 65
MX7D_PAD_ENET1_RGMII_RD2__GPIO7_IO2 0x14 // DIS_D/CX @ SODIMM 63
&ecspi3 {
// Enable the SPI controller
status = "okay";
// needed to avoid dtc warning
#address-cells = <1>;
#size-cells = <0>;
mcp2515: can@0 {
compatible = "microchip,mcp2515";
pinctrl-names = "default";
pinctrl-0 = <&pinctrl_can_int>;
reg = <0>;
clocks = <&clk16m>;
interrupt-parent = <&gpio5>;
interrupts = <2 IRQ_TYPE_EDGE_FALLING>;
spi-max-frequency = <10000000>;
status = "disabled";
spidev0: spidev@0 {
compatible = "toradex,evalspi";
reg = <0>;
spi-max-frequency = <23000000>;
panel@0 {
compatible = "sitronix,st7789v";
pinctrl-0 = <&pinctrl_disp_gpio>;
reg = <0>;
reset-gpios = <&gpio4 23 GPIO_ACTIVE_HIGH>;
backlight = <&pwm1>;
power-supply = <®_module_5v>;
spi-max-frequency = <100000>;
spi-cpol;
spi-cpha;
port {
panel_input: endpoint {
remote-endpoint = <&tcon0_out_panel>;
Where I commented “port” because I don’t know how to define it. Is it mandatory?
In this way I have no error in dmesg, but I don’t have any /dev/fb interface.
Is there anybody that are able to use this display via “drm” and “panel” driver (or a similar fb display)? Because I don’t see anybody that are using this interface and it’s very poor documented.
I there anyone that can address me to define the devicetree in the correct way? Also about the port?
Thanks a lot!
Valerio
