SSH error Authentication failed Toradex
Technical Support queries
Dear Support,
With putty, I can connect my device, but with VS code through the network, I can’t. Please see the image below.
Mehrdad
Hi @Mehrdad ,
Just to be sure, are you inputting the correct credentials when adding the device i.e. the same ones in Putty? On my side (on a GNU/Linux machine) the message only appears when inputting an incorrect username and/or password.
Does the error persist if you remove the stable Torizon extension and install the early access version instead, or vice-versa?
Lucas Akira
Hi @lucas_a.tx ,
The IP address and password I entered are correct.
you are right when I tried to uninstall the Toradex Torizon Support and install the Toradex Torizon Support (Early Access) happened after that. after that, I uninstall and install again the VS code but still has issues.
Mehrdad
Hi @Mehrdad !
Could you please share the logs from Moses in text (not a screenshot)?
You can get them from the Outputs tab of VS Code itself by selecting “Torizon IDE Backend process”. See the reference image below:
Edit: fixed the place from where the logs should be grabbed.
