Thanks for your support. Are you testing on a Viola board like me?
I flashed my device via SD card and ‘run setupdate; run update’. As far as i see these commands should update the dtb and kernel, right?
[ 0.000000] Initializing cgroup subsys cpu
[ 0.000000] Initializing cgroup subsys cpuacct
[ 0.000000] Linux version 4.1.44-2.7.4+gb1555bf (user@user-VirtualBox) (gcc version 6.2.1 20161016 (Linaro GCC 6.2-2016.11) ) #1 SMP Tue Jan 16 16:01:51 CET 2018
[ 0.000000] CPU: ARMv7 Processor [410fc075] revision 5 (ARMv7), cr=10c5387d
[ 0.000000] CPU: PIPT / VIPT nonaliasing data cache, VIPT aliasing instruction cache
[ 0.000000] Machine model: Toradex Colibri iMX7D on Colibri Evaluation Board V3
[ 0.000000] Reserved memory: created CMA memory pool at 0x98000000, size 128 MiB
[ 0.000000] Reserved memory: initialized node linux,cma, compatible id shared-dma-pool
[ 0.000000] Memory policy: Data cache writealloc
[ 0.000000] On node 0 totalpages: 131072
[ 0.000000] free_area_init_node: node 0, pgdat 808fa140, node_mem_map 97bba000
[ 0.000000] Normal zone: 1024 pages used for memmap
[ 0.000000] Normal zone: 0 pages reserved
[ 0.000000] Normal zone: 131072 pages, LIFO batch:31
[ 0.000000] PERCPU: Embedded 12 pages/cpu @97b80000 s16844 r8192 d24116 u49152
[ 0.000000] pcpu-alloc: s16844 r8192 d24116 u49152 alloc=12*4096
[ 0.000000] pcpu-alloc: [0] 0 [0] 1
[ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 130048
[ 0.000000] Kernel command line: clk_ignore_unused ubi.mtd=ubi root=ubi0:rootfs rootfstype=ubifs ubi.fm_autoconvert=1 console=tty1 console=ttymxc0,115200n8 consoleblank=0
[ 0.000000] PID hash table entries: 2048 (order: 1, 8192 bytes)
[ 0.000000] Dentry cache hash table entries: 65536 (order: 6, 262144 bytes)
[ 0.000000] Inode-cache hash table entries: 32768 (order: 5, 131072 bytes)
[ 0.000000] Memory: 378604K/524288K available (6414K kernel code, 291K rwdata, 2144K rodata, 312K init, 380K bss, 14612K reserved, 131072K cma-reserved)
[ 0.000000] Virtual kernel memory layout:
[ 0.000000] vector : 0xffff0000 - 0xffff1000 ( 4 kB)
[ 0.000000] fixmap : 0xffc00000 - 0xfff00000 (3072 kB)
[ 0.000000] vmalloc : 0xa0800000 - 0xff000000 (1512 MB)
[ 0.000000] lowmem : 0x80000000 - 0xa0000000 ( 512 MB)
[ 0.000000] modules : 0x7f000000 - 0x80000000 ( 16 MB)
[ 0.000000] .text : 0x80008000 - 0x80863c68 (8560 kB)
[ 0.000000] .init : 0x80864000 - 0x808b2000 ( 312 kB)
[ 0.000000] .data : 0x808b2000 - 0x808fadc0 ( 292 kB)
[ 0.000000] .bss : 0x808fd000 - 0x8095c1ac ( 381 kB)
[ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=2, Nodes=1
[ 0.000000] Hierarchical RCU implementation.
[ 0.000000] RCU restricting CPUs from NR_CPUS=4 to nr_cpu_ids=2.
[ 0.000000] RCU: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=2
[ 0.000000] NR_IRQS:16 nr_irqs:16 16
[ 0.000000] Architected cp15 timer(s) running at 8.00MHz (phys).
[ 0.000000] clocksource arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x1d854df40, max_idle_ns: 440795202120 ns
[ 0.000007] sched_clock: 56 bits at 8MHz, resolution 125ns, wraps every 2199023255500ns
[ 0.000019] Switching to timer-based delay loop, resolution 125ns
[ 0.000467] mxc_clocksource_init 3000000
[ 0.000480] Ignoring duplicate/late registration of read_current_timer delay
[ 0.000497] clocksource mxc_timer1: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 637086815595 ns
[ 0.001738] Console: colour dummy device 80x30
[ 0.002376] console [tty1] enabled
[ 0.002404] Calibrating delay loop (skipped), value calculated using timer frequency.. 16.00 BogoMIPS (lpj=80000)
[ 0.002446] pid_max: default: 32768 minimum: 301
[ 0.002565] Mount-cache hash table entries: 1024 (order: 0, 4096 bytes)
[ 0.002594] Mountpoint-cache hash table entries: 1024 (order: 0, 4096 bytes)
[ 0.003235] Initializing cgroup subsys freezer
[ 0.003274] Initializing cgroup subsys debug
[ 0.003328] CPU: Testing write buffer coherency: ok
[ 0.003636] Setting up static identity map for 0x80008280 - 0x800082d8
[ 0.005583] Brought up 2 CPUs
[ 0.005616] SMP: Total of 2 processors activated (32.00 BogoMIPS).
[ 0.005638] CPU: All CPU(s) started in SVC mode.
[ 0.006183] devtmpfs: initialized
[ 0.019527] VFP support v0.3: implementor 41 architecture 2 part 30 variant 7 rev 5
[ 0.019962] clocksource jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
[ 0.020022] futex hash table entries: 512 (order: 3, 32768 bytes)
[ 0.025227] pinctrl core: initialized pinctrl subsystem
[ 0.025766] regulator-dummy: no parameters
[ 0.026489] NET: Registered protocol family 16
[ 0.032278] DMA: preallocated 256 KiB pool for atomic coherent allocations
[ 0.059970] cpuidle: using governor ladder
[ 0.089987] cpuidle: using governor menu
[ 0.098822] vdd1p0d: 800 <--> 1200 mV at 1000 mV
[ 0.099267] vdd1p2: 1100 <--> 1300 mV
[ 0.102924] DDR type is DDR3!
[ 0.109560] imx7d_enet_clk_sel: failed to get enet_out clock, assuming ext. clock source
[ 0.109649] hw-breakpoint: found 5 (+1 reserved) breakpoint and 4 watchpoint registers.
[ 0.109684] hw-breakpoint: maximum watchpoint size is 8 bytes.
[ 0.110054] imx7d-pinctrl 30270000.lpsr-gpr: initialized IMX pinctrl driver
[ 0.110255] imx7d-pinctrl 302c0000.iomuxc-lpsr: initialized IMX pinctrl driver
[ 0.111560] imx7d-pinctrl 30330000.iomuxc: initialized IMX pinctrl driver
[ 0.112519] imx-gpcv2 303a0000.gpc: Looking up mipi-phy-supply from device tree
[ 0.112595] imx-gpcv2 303a0000.gpc: Looking up pcie-phy-supply from device tree
[ 0.112645] imx-gpcv2 303a0000.gpc: Looking up vcc-supply from device tree
[ 0.113215] MU is ready for cross core communication!
[ 0.123120] mxs-dma 33000000.dma-apbh: initialized
[ 0.123814] +V3.3: 3300 mV
[ 0.123863] reg-fixed-voltage regulator-module-3v3: +V3.3 supplying 3300000uV
[ 0.124053] +V3.3_AVDD_AUDIO: 3300 mV
[ 0.124103] reg-fixed-voltage regulator-module-3v3-avdd: +V3.3_AVDD_AUDIO supplying 3300000uV
[ 0.124296] 3.3V: 3300 mV
[ 0.124332] reg-fixed-voltage regulator-3v3: 3.3V supplying 3300000uV
[ 0.124532] 5V: 5000 mV
[ 0.124569] reg-fixed-voltage regulator-5v0: 5V supplying 5000000uV
[ 0.124719] /regulator-usbh-vbus: could not find phandle
[ 0.124893] VCC_USB[1-4]: 5000 mV
[ 0.124950] reg-fixed-voltage regulator-usbh-vbus: Looking up vin-supply from device tree
[ 0.124976] VCC_USB[1-4]: supplied by 5V
[ 0.125037] reg-fixed-voltage regulator-usbh-vbus: VCC_USB[1-4] supplying 5000000uV
[ 0.125449] SCSI subsystem initialized
[ 0.125762] usbcore: registered new interface driver usbfs
[ 0.125850] usbcore: registered new interface driver hub
[ 0.125977] usbcore: registered new device driver usb
[ 0.126214] usb_phy_generic 30800000.aips-bus:usbphy_nop1: Looking up vcc-supply from device tree
[ 0.126230] usb_phy_generic 30800000.aips-bus:usbphy_nop1: Looking up vcc-supply property in node /soc/aips-bus@30800000/usbphy_nop1 failed
[ 0.126242] 30800000.aips-bus:usbphy_nop1 supply vcc not found, using dummy regulator
[ 0.126402] usb_phy_generic 30800000.aips-bus:usbphy_nop3: Looking up vcc-supply from device tree
[ 0.126524] usb_phy_generic 30800000.aips-bus:usbphy_nop2: Looking up vcc-supply from device tree
[ 0.126540] usb_phy_generic 30800000.aips-bus:usbphy_nop2: Looking up vcc-supply property in node /soc/aips-bus@30800000/usbphy_nop2 failed
[ 0.126549] 30800000.aips-bus:usbphy_nop2 supply vcc not found, using dummy regulator
[ 0.127601] i2c i2c-0: IMX I2C adapter registered
[ 0.127633] i2c i2c-0: can't use DMA
[ 0.128115] i2c i2c-3: IMX I2C adapter registered
[ 0.128144] i2c i2c-3: can't use DMA
[ 0.128272] Linux video capture interface: v2.00
[ 0.128345] pps_core: LinuxPPS API ver. 1 registered
[ 0.128370] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[ 0.128435] PTP clock support registered
[ 0.128968] Advanced Linux Sound Architecture Driver Initialized.
[ 0.130335] Switched to clocksource arch_sys_counter
[ 0.141343] NET: Registered protocol family 2
[ 0.142172] TCP established hash table entries: 4096 (order: 2, 16384 bytes)
[ 0.142257] TCP bind hash table entries: 4096 (order: 3, 32768 bytes)
[ 0.142350] TCP: Hash tables configured (established 4096 bind 4096)
[ 0.142423] UDP hash table entries: 256 (order: 1, 8192 bytes)
[ 0.142472] UDP-Lite hash table entries: 256 (order: 1, 8192 bytes)
[ 0.142667] NET: Registered protocol family 1
[ 0.142981] RPC: Registered named UNIX socket transport module.
[ 0.143008] RPC: Registered udp transport module.
[ 0.143029] RPC: Registered tcp transport module.
[ 0.143050] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 0.144292] imx rpmsg driver is registered.
[ 0.145276] Bus freq driver module loaded
[ 0.153288] VFS: Disk quotas dquot_6.6.0
[ 0.153533] VFS: Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
[ 0.155463] NFS: Registering the id_resolver key type
[ 0.155530] Key type id_resolver registered
[ 0.155552] Key type id_legacy registered
[ 0.155589] nfs4filelayout_init: NFSv4 File Layout Driver Registering...
[ 0.156157] ntfs: driver 2.1.32 [Flags: R/W].
[ 0.156699] fuse init (API version 7.23)
[ 0.160373] io scheduler noop registered
[ 0.160438] io scheduler deadline registered
[ 0.160643] io scheduler cfq registered (default)
[ 0.162572] pwm-backlight backlight: Looking up power-supply from device tree
[ 0.162590] pwm-backlight backlight: Looking up power-supply property in node /backlight failed
[ 0.162605] backlight supply power not found, using dummy regulator
[ 0.164561] mxsfb 30730000.lcdif: Looking up lcd-supply from device tree
[ 0.164578] mxsfb 30730000.lcdif: Looking up lcd-supply property in node /soc/aips-bus@30400000/lcdif@30730000 failed
[ 0.164588] 30730000.lcdif supply lcd not found, using dummy regulator
[ 0.230391] mxsfb 30730000.lcdif: failed to find mxc display driver
[ 0.239138] Console: switching to colour frame buffer device 80x30
[ 0.256872] mxsfb 30730000.lcdif: initialized
[ 0.259676] imx-sdma 30bd0000.sdma: no event needs to be remapped
[ 0.261513] imx-sdma 30bd0000.sdma: loaded firmware 4.2
[ 0.266372] imx-sdma 30bd0000.sdma: initialized
[ 0.269127] 30860000.serial: ttymxc0 at MMIO 0x30860000 (irq = 246, base_baud = 1500000) is a IMX
[ 0.989929] console [ttymxc0] enabled
[ 0.996053] 30880000.serial: ttymxc2 at MMIO 0x30880000 (irq = 247, base_baud = 5000000) is a IMX
[ 1.014484] loop: module loaded
[ 1.021266] DCDC1: 1000 <--> 1100 mV at 1000 mV
[ 1.022618] DCDC2: 975 <--> 1100 mV at 1100 mV
[ 1.023933] DCDC3: 1800 mV
[ 1.025239] DCDC4: 1350 mV
[ 1.026556] LDO1: 1800 <--> 3300 mV at 3300 mV
[ 1.027336] LDO2: 1800 <--> 3300 mV at 3300 mV
[ 1.028110] LDO3: 3300 mV
[ 1.028898] LDO4: 1800 mV
[ 1.029667] LDO5: 3300 mV
[ 1.030505] LDORTC1: at 3000 mV
[ 1.031288] LDORTC2: at 900 mV
[ 1.039099] nand: device found, Manufacturer ID: 0xc2, Chip ID: 0xdc
[ 1.047354] nand: Macronix MX30LF4G28AB
[ 1.052993] nand: 512 MiB, SLC, erase size: 128 KiB, page size: 2048, OOB size: 112
[ 1.064697] gpmi-nand 33002000.gpmi-nand: enable the asynchronous EDO mode 5
[ 1.073872] Bad block table found at page 262080, version 0x01
[ 1.081837] Bad block table found at page 262016, version 0x01
[ 1.089891] 5 ofpart partitions found on MTD device gpmi-nand
[ 1.097575] Creating 5 MTD partitions on "gpmi-nand":
[ 1.104588] 0x000000000000-0x000000080000 : "mx7-bcb"
[ 1.112083] 0x000000080000-0x000000200000 : "u-boot1"
[ 1.119433] 0x000000200000-0x000000380000 : "u-boot2"
[ 1.126716] 0x000000380000-0x000000400000 : "u-boot-env"
[ 1.134202] 0x000000400000-0x000020000000 : "ubi"
[ 1.141863] gpmi-nand 33002000.gpmi-nand: driver registered.
[ 1.150566] /soc/aips-bus@30800000/spba-bus@30800000/ecspi@30840000: could not find phandle
[ 1.162685] /soc/aips-bus@30800000/spba-bus@30800000/ecspi@30840000: could not find phandle
[ 1.174786] spi_imx 30840000.ecspi: probed
[ 1.182660] fec 30be0000.ethernet: Looking up phy-supply from device tree
[ 1.183182] pps pps0: new PPS source ptp0
[ 1.191199] libphy: fec_enet_mii_bus: probed
[ 1.198917] fec 30be0000.ethernet eth0: registered PHC device 0
[ 1.206811] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[ 1.215199] ehci-mxc: Freescale On-Chip EHCI Host driver
[ 1.222549] usbcore: registered new interface driver usb-storage
[ 1.230545] usbcore: registered new interface driver usbserial
[ 1.238191] usbcore: registered new interface driver usbserial_generic
[ 1.246461] usbserial: USB Serial support registered for generic
[ 1.254190] usbcore: registered new interface driver ftdi_sio
[ 1.261623] usbserial: USB Serial support registered for FTDI USB Serial Device
[ 1.272343] usbcore: registered new interface driver pl2303
[ 1.279692] usbserial: USB Serial support registered for pl2303
[ 1.288512] usbmisc_imx 30b10200.usbmisc: Looking up vbus-wakeup-supply from device tree
[ 1.288529] usbmisc_imx 30b10200.usbmisc: Looking up vbus-wakeup-supply property in node /soc/aips-bus@30800000/usbmisc@30b10200 failed
[ 1.288551] 30b10200.usbmisc supply vbus-wakeup not found, using dummy regulator
[ 1.299749] usbmisc_imx 30b30200.usbmisc: Looking up vbus-wakeup-supply from device tree
[ 1.299765] usbmisc_imx 30b30200.usbmisc: Looking up vbus-wakeup-supply property in node /soc/aips-bus@30800000/usbmisc@30b30200 failed
[ 1.299777] 30b30200.usbmisc supply vbus-wakeup not found, using dummy regulator
[ 1.311289] usbmisc_imx 30b20200.usbmisc: Looking up vbus-wakeup-supply from device tree
[ 1.311305] usbmisc_imx 30b20200.usbmisc: Looking up vbus-wakeup-supply property in node /soc/aips-bus@30800000/usbmisc@30b20200 failed
[ 1.311316] 30b20200.usbmisc supply vbus-wakeup not found, using dummy regulator
[ 1.323532] imx_usb 30b10000.usb: Can't register ci_hdrc platform device, err=-517
[ 1.335463] imx_usb 30b20000.usb: Looking up vbus-supply from device tree
[ 1.338305] ci_hdrc ci_hdrc.0: EHCI Host Controller
[ 1.345286] ci_hdrc ci_hdrc.0: new USB bus registered, assigned bus number 1
[ 1.370368] ci_hdrc ci_hdrc.0: USB 2.0 started, EHCI 1.00
[ 1.378818] hub 1-0:1.0: USB hub found
[ 1.384734] hub 1-0:1.0: 1 port detected
[ 1.391681] mousedev: PS/2 mouse device common for all mice
[ 1.402080] input: AD7879 Touchscreen as /devices/platform/soc/30800000.aips-bus/30a20000.i2c/i2c-0/0-002c/input/input0
[ 1.420004] rtc-ds1307 3-0068: oscillator failed, set time!
[ 1.427962] rtc-ds1307 3-0068: rtc core: registered m41t0 as rtc0
[ 1.436874] snvs_rtc 30370000.snvs:snvs-rtc-lp: rtc core: registered 30370000.snvs:snvs- as rtc1
[ 1.450172] i2c /dev entries driver
[ 1.458573] imx2-wdt 30280000.wdog: timeout 60 sec (nowayout=0)
[ 1.467012] sdhci: Secure Digital Host Controller Interface driver
[ 1.475380] sdhci: Copyright(c) Pierre Ossman
[ 1.481891] sdhci-pltfm: SDHCI platform and OF driver helper
[ 1.490544] /soc/aips-bus@30800000/usdhc@30b40000: voltage-ranges unspecified
[ 1.499856] sdhci-esdhc-imx 30b40000.usdhc: Got CD GPIO
[ 1.508797] sdhci-esdhc-imx 30b40000.usdhc: Looking up vmmc-supply from device tree
[ 1.508917] sdhci-esdhc-imx 30b40000.usdhc: Looking up vqmmc-supply from device tree
[ 1.508933] sdhci-esdhc-imx 30b40000.usdhc: Looking up vqmmc-supply property in node /soc/aips-bus@30800000/usdhc@30b40000 failed
[ 1.508959] sdhci-esdhc-imx 30b40000.usdhc: No vqmmc regulator found
[ 1.560499] mmc0: SDHCI controller on 30b40000.usdhc [30b40000.usdhc] using ADMA
[ 1.585530] caam 30900000.caam: Entropy delay = 3200
[ 1.592598] caam 30900000.caam: Instantiated RNG4 SH0
[ 1.652011] caam 30900000.caam: Instantiated RNG4 SH1
[ 1.658956] caam 30900000.caam: device ID = 0x0a16030000000000 (Era -524)
[ 1.667666] caam 30900000.caam: job rings = 3, qi = 0
[ 1.668698] mmc0: new high speed SDHC card at address 1234
[ 1.669207] mmcblk0: mmc0:1234 SA04G 3.64 GiB
[ 1.682072] mmcblk0: p1 p2
[ 1.785417] caam algorithms registered in /proc/crypto
[ 1.795879] caam_jr 30901000.jr0: registering rng-caam
[ 1.803587] hidraw: raw HID events driver (C) Jiri Kosina
[ 1.811312] usbcore: registered new interface driver usbhid
[ 1.818703] usbhid: USB HID core driver
[ 1.825491] imx7d_adc 30610000.adc: Looking up vref-supply from device tree
[ 1.826354] imx7d_adc 30620000.adc: Looking up vref-supply from device tree
[ 1.829033] coresight-tmc 30086000.etr: TMC initialized
[ 1.836435] coresight-tmc 30084000.etf: TMC initialized
[ 1.843620] coresight-tpiu 30087000.tpiu: TPIU initialized
[ 1.851157] coresight-funnel 30083000.funnel: FUNNEL initialized
[ 1.859052] coresight-funnel 30041000.funnel: FUNNEL initialized
[ 1.866987] coresight-replicator replicator: REPLICATOR initialized
[ 1.875495] coresight-etm3x 3007c000.etm: ETM initialized
[ 1.882914] coresight-etm3x 3007d000.etm: ETM initialized
[ 1.892881] sgtl5000 0-000a: Looking up VDDD-supply from device tree
[ 1.893007] sgtl5000 0-000a: Looking up VDDA-supply from device tree
[ 1.893099] sgtl5000 0-000a: Looking up VDDIO-supply from device tree
[ 1.893164] sgtl5000 0-000a: Looking up VDDD-supply from device tree
[ 1.894671] sgtl5000 0-000a: sgtl5000 revision 0x11
[ 1.937496] imx-sgtl5000 sound: sgtl5000 <-> 308a0000.sai mapping ok
[ 1.946710] Netfilter messages via NETLINK v0.30.
[ 1.952984] nfnl_acct: registering with nfnetlink.
[ 1.959273] nf_conntrack version 0.5.0 (7963 buckets, 31852 max)
[ 1.967338] nf_tables: (c) 2007-2009 Patrick McHardy <kaber@trash.net>
[ 1.975936] ip_tables: (C) 2000-2006 Netfilter Core Team
[ 1.983640] NET: Registered protocol family 10
[ 1.990838] ip6_tables: (C) 2000-2006 Netfilter Core Team
[ 1.997881] NET: Registered protocol family 17
[ 2.004018] bridge: automatic filtering via arp/ip/ip6tables has been deprecated. Update your scripts to load br_netfilter if you need this.
[ 2.020031] Bridge firewalling registered
[ 2.025833] 8021q: 802.1Q VLAN Support v1.8
[ 2.031787] Key type dns_resolver registered
[ 2.038217] cpu cpu0: Looking up arm-supply from device tree
[ 2.044986] Registering SWP/SWPB emulation handler
[ 2.052475] registered taskstats version 1
[ 2.061072] imx_usb 30b10000.usb: Looking up vbus-supply from device tree
[ 2.064584] ci_hdrc ci_hdrc.1: EHCI Host Controller
[ 2.070948] ci_hdrc ci_hdrc.1: new USB bus registered, assigned bus number 2
[ 2.090439] ci_hdrc ci_hdrc.1: USB 2.0 started, EHCI 1.00
[ 2.098041] hub 2-0:1.0: USB hub found
[ 2.103261] hub 2-0:1.0: 1 port detected
[ 2.110357] ubi0: default fastmap pool size: 200
[ 2.116363] ubi0: default fastmap WL pool size: 100
[ 2.122645] ubi0: attaching mtd4
[ 2.218529] ubi0: attached by fastmap
[ 2.223922] ubi0: fastmap pool size: 200
[ 2.229449] ubi0: fastmap WL pool size: 100
[ 2.243195] ubi0: attached mtd4 (name "ubi", size 508 MiB)
[ 2.249983] ubi0: PEB size: 131072 bytes (128 KiB), LEB size: 126976 bytes
[ 2.258186] ubi0: min./max. I/O unit sizes: 2048/2048, sub-page size 2048
[ 2.266283] ubi0: VID header offset: 2048 (aligned 2048), data offset: 4096
[ 2.274580] ubi0: good PEBs: 4060, bad PEBs: 4, corrupted PEBs: 0
[ 2.281998] ubi0: user volume: 4, internal volumes: 1, max. volumes count: 128
[ 2.291819] ubi0: max/mean erase counter: 10/3, WL threshold: 4096, image sequence number: 0
[ 2.302885] ubi0: available PEBs: 0, total reserved PEBs: 4060, PEBs reserved for bad PEB handling: 76
[ 2.314998] ubi0: background thread "ubi_bgt0d" started, PID 143
[ 2.315763] input: gpio-keys as /devices/platform/gpio-keys/input/input1
[ 2.332270] rtc-ds1307 3-0068: hctosys: unable to read the hardware clock
[ 2.354656] clk: Not disabling unused clocks
[ 2.360570] ALSA device list:
[ 2.365016] #0: imx7-colibri-sgtl5000
[ 2.394004] UBIFS (ubi0:3): UBIFS: mounted UBI device 0, volume 3, name "rootfs", R/O mode
[ 2.405400] UBIFS (ubi0:3): LEB size: 126976 bytes (124 KiB), min./max. I/O unit sizes: 2048 bytes/2048 bytes
[ 2.418619] UBIFS (ubi0:3): FS size: 493936640 bytes (471 MiB, 3890 LEBs), journal size 9023488 bytes (8 MiB, 72 LEBs)
[ 2.432838] UBIFS (ubi0:3): reserved for root: 0 bytes (0 KiB)
[ 2.440534] UBIFS (ubi0:3): media format: w4/r0 (latest is w4/r0), UUID CC992764-19B8-484F-8E58-91CABEC18359, small LPT model
[ 2.456406] VFS: Mounted root (ubifs filesystem) readonly on device 0:13.
[ 2.465535] devtmpfs: mounted
[ 2.470679] Freeing unused kernel memory: 312K
[ 2.573081] random: nonblocking pool is initialized
[ 2.584900] systemd[1]: System time before build time, advancing clock.
[ 2.614653] systemd[1]: systemd 230 running in system mode. (+PAM -AUDIT -SELINUX +IMA -APPARMOR +SMACK +SYSVINIT +UTMP -LIBCRYPTSETUP -GCRYPT -GNUTLS -ACL -XZ +LZ4 -SECCO)
[ 2.639151] systemd[1]: Detected architecture arm.
[ 2.671219] systemd[1]: Set hostname to <LCRTS>.
[ 2.679456] systemd[1]: Initializing machine ID from random generator.
[ 2.687932] systemd[1]: Installed transient /etc/machine-id file.
[ 2.952411] systemd[1]: Started Dispatch Password Requests to Console Directory Watch.
[ 2.982249] systemd[1]: Created slice User and Session Slice.
[ 3.010537] systemd[1]: Reached target Swap.
[ 3.031176] systemd[1]: Listening on udev Control Socket.
[ 3.078646] systemd[1]: Reached target Remote File Systems.
[ 3.100849] systemd[1]: Started Forward Password Requests to Wall Directory Watch.
[ 3.130559] systemd[1]: Reached target Paths.
[ 3.150679] systemd[1]: Listening on udev Kernel Socket.
[ 3.180887] systemd[1]: Created slice System Slice.
[ 3.210584] systemd[1]: Reached target Slices.
[ 3.230887] systemd[1]: Created slice system-serial\x2dgetty.slice.
[ 3.260819] systemd[1]: Created slice system-getty.slice.
[ 3.290689] systemd[1]: Listening on /dev/initctl Compatibility Named Pipe.
[ 3.320745] systemd[1]: Listening on Journal Socket.
[ 3.353359] systemd[1]: Starting Setup Virtual Console...
[ 3.382209] systemd[1]: Starting File System Check on Root Device...
[ 3.412326] systemd[1]: Mounting Debug File System...
[ 3.433198] systemd[1]: Starting Create list of required static device nodes for the current kernel...
[ 3.472502] systemd[1]: Mounting Temporary Directory...
[ 3.501193] systemd[1]: Listening on Journal Socket (/dev/log).
[ 3.532628] systemd[1]: Starting Journal Service...
[ 3.560848] systemd[1]: Listening on Network Service Netlink Socket.
[ 3.594019] systemd[1]: Starting Load Kernel Modules...
[ 3.608834] systemd[1]: Mounted Debug File System.
[ 3.630739] systemd[1]: Mounted Temporary Directory.
[ 3.651812] systemd[1]: Started Setup Virtual Console.
[ 3.681331] systemd[1]: Started File System Check on Root Device.
[ 3.711623] systemd[1]: Started Create list of required static device nodes for the current kernel.
[ 3.741637] systemd[1]: Started Load Kernel Modules.
[ 3.771041] systemd[1]: Started Journal Service.
[ 3.882790] UBIFS (ubi0:3): start fixing up free space
[ 9.672660] UBIFS (ubi0:3): free space fixup complete
[ 9.685553] UBIFS (ubi0:3): background thread "ubifs_bgt0_3" started, PID 182
[ 9.836975] systemd-journald[166]: Received request to flush runtime journal from PID 1
[ 12.963992] using random self ethernet address
[ 12.969911] using random host ethernet address
[ 13.320686] usb0: HOST MAC 00:14:2d:ff:ff:fe
[ 13.326929] usb0: MAC 00:14:2d:ff:ff:ff
[ 13.561067] FAT-fs (mmcblk0p2): Volume was not properly unmounted. Some data may be corrupt. Please run fsck.
[ 13.610539] fec 30be0000.ethernet eth0: Freescale FEC PHY driver [Micrel KSZ8041] (mii_bus:phy_addr=30be0000.etherne:00, irq=-1)
[ 13.644724] FAT-fs (mmcblk0p1): Volume was not properly unmounted. Some data may be corrupt. Please run fsck.
[ 13.660676] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
[ 13.725561] IPv6: ADDRCONF(NETDEV_UP): usb0: link is not ready
