Please help us with how to enable/access SPI for Apalis i.MX8 / Ixora Carrier using VS Code Torizon IDE.
Apalis i.MX8 WB IT v1.1A
Ixora v1.3A
Torizen OS
VS Code Torizon IDE
Ixora v1.3A
Torizen OS
VS Code Torizon IDE
Hello! I’d be happy to guide you through enabling and accessing SPI on your Apalis i.MX8 with Torizon OS using the VS Code Torizon IDE.
Here are the steps you should follow:
First, open a terminal on your module (either via SSH or the Torizon VS Code extension). Run:
ls /dev/apalis-spi*
You should see something like /dev/apalis-spi1-cs0 or /dev/apalis-spi2-cs0. If you do, the SPI interfaces are enabled.
If you do not see the SPI device nodes, you may need to enable them:
Make sure the device tree overlays for SPI are enabled in your device configuration. For Torizon OS, you can add overlays using the TorizonCore Builder tool or via the Torizon VS Code extension’s “Device Configuration” area.
Typical overlays are named like apalis-imx8_spidev.dtbo. You can refer to the SPI on Torizon instructions.
If you want your VS Code Torizon IDE project (container) to access SPI:
.devcontainer/devcontainer.json, add the following section:"runArgs": [
"--device=/dev/apalis-spi1-cs0",
"--device=/dev/apalis-spi2-cs0"
Or, adapt depending on which devices you need.
Tip: Always use the absolute device node (not symlink) to avoid read-only filesystem issues.
You may now use Python, C, or another language in your container to open /dev/apalis-spi1-cs0 or /dev/apalis-spi2-cs0 for SPI communications.
Generally, containers started like above will have access. If needed, you might also need to add your application’s user to the spi group, or run as root (for quick tests).
If you need to unbind another driver or manually bind spidev, see the detailed instructions in the links above.
Let me know if you need further clarification on any step!
The file .devcontainer/devcontainer.json is not available in my workspace. Where do I find it.
So have you checked these pages?
You can also find some samples in our samples github repository.
Is there something specific that you need help with?
