Speaker test failed on new TK1
I have a new TK1 connected to an Ixora board installed with “Apalis-TK1-Mainline_LXDE-Image 2.7.2 20170410”
When I run speaker test it fails with the following error message.
root@apalis-tk1-mainline:~# speaker-test --device hw:0,0 --rate 48000 --channels 2 --format S16_LE --test wav
speaker-test 1.1.2
Playback device is hw:0,0
Stream parameters are 48000Hz, S16_LE, 2 channels
WAV file(s)
Playback open error: -2,No such file or directory
root@apalis-tk1-mainline:~# aplay -L
null
Discard all samples (playback) or generate zero samples (capture)
default:CARD=TK1
Toradex Apalis TK1,
Default Audio Device
sysdefault:CARD=TK1
Toradex Apalis TK1,
root@apalis-tk1-mainline:~# aplay -l
**** List of PLAYBACK Hardware Devices ****
card 0: tegrahda [tegra-hda], device 3: HDMI 0 [HDMI 0]
Subdevices: 1/1
Subdevice #0: subdevice #0
card 1: TK1 [Toradex Apalis TK1], device 0: HiFi sgtl5000-0
Subdevices: 1/1
hw:0,0 - refers to HDMI
and to play through the default 3.5mm, I needed to use hw:1,0 to refer to the first device on the second card.
