Sound driver problem
I found sound driver problem during boot on IMX6 module:
ASoC: driver name too long ‘imx6dl-colibri-sgtl5000’ → ‘imx6dl-colibri-’
Do you plan to fix this issue?
my kernel version: Linux version 6.1.21-6.2.0
module type: IMX6DL
Radoslav
Hi @idest ,
Thanks for your question.
Does the sound driver work when you see the message or no?
Which version of the module are you on?
Kevin
Sounds are played good. It looks that is only warning.
