I want to compile the RT kernel for the imx7-emmc. I edited the configuration file (colibri-imx7-emmc.conf) to use ‘linux-toradex-rt’ as kernel provider. Now when compiling the kernel (bitbake virtual/kernel) i get the following error message below. Please find attached the logfile. Any help would be appreciated.
| HOSTCC scripts/mod/modpost.o
| HOSTCC scripts/mod/sumversion.o
| GEN scripts/mod/devicetable-offsets.h
| HOSTCC scripts/mod/file2alias.o
| HOSTLD scripts/mod/modpost
| make[3]: *** No rule to make target 'arch/arm/boot/dts/imx7d-colibri-emmc-eval-v3.dtb'. Stop.
| arch/arm/Makefile:322: recipe for target 'imx7d-colibri-emmc-eval-v3.dtb' failed
| make[2]: *** [imx7d-colibri-emmc-eval-v3.dtb] Error 2
| Makefile:146: recipe for target 'sub-make' failed
| make[1]: *** [sub-make] Error 2
| Makefile:24: recipe for target '__sub-make' failed
| make: *** [__sub-make] Error 2
| ERROR: Function failed: do_compile (log file is located at /home/user/oe-core/build/tmp-glibc/work/colibri_imx7_emmc-angstrom-linux-gnueabi/linux-toradex-rt/4.1-2.0.x-2.7.5-rt/temp/log.do_compile.12024)
ERROR: Task (/home/user/oe-core/build/../layers/meta-toradex-nxp/recipes-kernel/linux/linux-toradex-rt_4.1-2.0.x.bb:do_compile) failed with exit code '1'
NOTE: Tasks Summary: Attempted 616 tasks of which 609 didn't need to be rerun and 1 failed.
NOTE: Writing buildhistory
Summary: 1 task failed:
Seems like '‘imx7d-colibri-emmc-eval-v3.dtsi’ is missing at revision 82f0f4f012a646a735d6b44de77b7c9d0712c714 in linux-toradex-rt_4.1-2.0.x.bb which is different to the revision specified in linux-toradex_4.1-2.0.x.bb.
You are right, real time is not supported in bsp 2.7 with imx7-emmc machine. If you want the real time in bsp 2.7, then you update the revision to newer one but then you might also have to apply the newer real time patch or you update to Bsp 2.8.
Best regards, Jaski
I wrote a recipe append which copies the missing dts files before compiling there kernel. Now the kernel builds successfully, but however, CAN does not work anymore… Does CAN work with BSP 2.8-RT?
