Currently, the I2C library supports only one I2C instance at a time for WEC7 on T30. (I2C lib ver. 4.4). So the mutex technique has to be used. Is in your plan to support more I2C instances at a time in the future?
Thank you very much
Martin
Currently we have no plan to support multiple instances the same time.
Possible workarounds:
- If you don’t use them the same time, just close one and open the other bus.
- Use the devices on the same bus addressing them by using the device address.
OK, thank you for these advices.
Martin
