I need to run applications packaged as Ubuntu snap files on a Toradex Colibri IMX6 based board (“mainboard” is custom).
For that, I need the snapd system service (for managing/running) and assorted paraphernalia (like kernel support for squashfs, some scripts/binaries in the rootfs, etc.)
I’m using the torizon yocto setup (linux kernel 5.4) with only some minor modifications;
The snapd package is added as a separate yocto layer (GitHub - morphis/meta-snappy: Snappy for Yocto/OpenEmbedded).
Everything builds, boots without errors and the snapd service is up and running, but as soon as I install snap files the service crashes with a SIGILL errors. From what I can tell this happens when Go code (snapd is written in C + Go) tries to call a C function (getpwnam_r
On an older (linux 4.9) pre-torizon build everything works.
- Any advice on how to fix this, or where to even start looking?
- Was there some change in the toolchain change that could be affecting Go inbetween the working (kernel 4.9) and nonworking (5.4) versions?
- Are there any steps that I could take to help narrow the problem down?
Full error message below.
Versions:
colibri-imx6-10614561:~$ sudo snap version
snap 2.38
snapd 2.38
series 16
torizon 0.0.0-devel-20200428160200-build.0
kernel 5.4.28-0.0.0-devel+git.9ef9ba76540e
Full error message:
$ sudo snap install hello-world
SIGILL: illegal instruction
PC=0x5a49c m=7 sigcode=1
goroutine 0 [idle]:
runtime: unexpected return pc for runtime.sigFetchG called from 0xa643261b
stack: frame={sp:0xa3dfcb94, fp:0xa3dfcba4} stack=[0xa35fd0c4,0xa3dfccc4)
a3dfcb14: a5a5d73d a34005f8 a5afc1bc 000003fe
a3dfcb24: a5a5f323 a5a5f305 00000000 a34005f8
a3dfcb34: a5a5690b a5afc1bc a644801e 00000000
a3dfcb44: 00000001 00000000 a4f00780 a3dfcbb8
a3dfcb54: 0180c0a0 a4f00b7f a3dfcbac 006f599c
a3dfcb64: a5a56999 00000001 00000000 a3dfcbb8
a3dfcb74: a34005f8 fbada488 a5a5d0f1 00000001
a3dfcb84: 00000400 00000001 00000400 0181c0a0
a3dfcb94: <a643261b 00000001 00000000 00000000
a3dfcba4: >a4f00780 00000000 00000000 0004c960 <runtime.schedule+712>
a3dfcbb4: 006d01fc 00010000 00000001 a34005f8
a3dfcbc4: 00000000 00000000 00000000 00000000
a3dfcbd4: 00000000 00000000 00000000 00000000
a3dfcbe4: 00000000 00000000 00000000 00000000
a3dfcbf4: 00000000 00000000 00000000 00000000
a3dfcc04: 00000000 00000000 00000000 00000000
a3dfcc14: 00000000 00000000 a3dfd7b0 a643255d
runtime.sigFetchG(0x0, 0x0)
/usr/lib/go/src/runtime/signal_unix.go:397 +0xd0
goroutine 1 [syscall]:
runtime.cgocall(0x4cb6e0, 0x190f70c, 0x1810020)
/usr/lib/go/src/runtime/cgocall.go:133 +0x5c fp=0x190f6f4 sp=0x190f6dc pc=0x12e7c
os/user._Cfunc_mygetpwnam_r(0x181c0a0, 0x180c0a0, 0xa4f00780, 0x400, 0x1810020, 0x0)
_cgo_gotypes.go:157 +0x38 fp=0x190f708 sp=0x190f6f4 pc=0x1aef04
os/user.lookupUser.func1.1(0x181c0a0, 0x8, 0x8, 0x180c0a0, 0x1810028, 0x1810020, 0x1afb10)
/usr/lib/go/src/os/user/cgo_lookup_unix.go:70 +0xbc fp=0x190f72c sp=0x190f708 pc=0x1b0488
os/user.lookupUser.func1(0x598af8)
/usr/lib/go/src/os/user/cgo_lookup_unix.go:70 +0x44 fp=0x190f74c sp=0x190f72c pc=0x1b050c
os/user.retryWithBuffer(0x1810028, 0x190f7c0, 0x7, 0x181c0a0)
/usr/lib/go/src/os/user/cgo_lookup_unix.go:247 +0x2c fp=0x190f774 sp=0x190f74c pc=0x1afc24
os/user.lookupUser(0x181a04a, 0x7, 0x0, 0x0, 0x0)
/usr/lib/go/src/os/user/cgo_lookup_unix.go:61 +0x130 fp=0x190f7e4 sp=0x190f774 pc=0x1af3c0
os/user.Lookup(0x181a04a, 0x7, 0x181a04a, 0x7, 0x0)
/usr/lib/go/src/os/user/lookup.go:36 +0x58 fp=0x190f808 sp=0x190f7e4 pc=0x1aebe0
github.com/snapcore/snapd/osutil.RealUser(0x5fe49a, 0x18, 0x0)
/workdir/torizon/build-torizon/tmp-torizon/work/armv7at2hf-neon-tdx-linux-gnueabi/snapd/2.38-r0/build/src/github.com/snapcore/snapd/osutil/user.go:162 +0x9c fp=0x190f824 sp=0x190f808 pc=0x1b8f50
github.com/snapcore/snapd/client.storeAuthDataFilename(0x0, 0x0, 0x1866000, 0x181a067)
/workdir/torizon/build-torizon/tmp-torizon/work/armv7at2hf-neon-tdx-linux-gnueabi/snapd/2.38-r0/build/src/github.com/snapcore/snapd/client/login.go:97 +0xac fp=0x190f854 sp=0x190f824 pc=0x3d2e70
github.com/snapcore/snapd/client.readAuthData(0x0, 0x0, 0x0)
/workdir/torizon/build-torizon/tmp-torizon/work/armv7at2hf-neon-tdx-linux-gnueabi/snapd/2.38-r0/build/src/github.com/snapcore/snapd/client/login.go:135 +0x4c fp=0x190f888 sp=0x190f854 pc=0x3d3144
github.com/snapcore/snapd/client.(*Client).setAuthorization(0x18991f0, 0x1866000, 0x190f964, 0x3)
/workdir/torizon/build-torizon/tmp-torizon/work/armv7at2hf-neon-tdx-linux-gnueabi/snapd/2.38-r0/build/src/github.com/snapcore/snapd/client/client.go:146 +0x14 fp=0x190f8ec sp=0x190f888 pc=0x3ce60c
github.com/snapcore/snapd/client.(*Client).raw(0x18991f0, 0x5f00a2, 0x3, 0x181c080, 0xe, 0x0, 0x0, 0x0, 0x0, 0x0, ...)
/workdir/torizon/build-torizon/tmp-torizon/work/armv7at2hf-neon-tdx-linux-gnueabi/snapd/2.38-r0/build/src/github.com/snapcore/snapd/client/client.go:204 +0x39c fp=0x190f9d4 sp=0x190f8ec pc=0x3cee84
github.com/snapcore/snapd/client.(*Client).do(0x18991f0, 0x5f00a2, 0x3, 0x181c080, 0xe, 0x0, 0x0, 0x0, 0x0, 0x57c108, ...)
/workdir/torizon/build-torizon/tmp-torizon/work/armv7at2hf-neon-tdx-linux-gnueabi/snapd/2.38-r0/build/src/github.com/snapcore/snapd/client/client.go:262 +0xe4 fp=0x190fa68 sp=0x190f9d4 pc=0x3cf0f8
github.com/snapcore/snapd/client.(*Client).doSync(0x18991f0, 0x5f00a2, 0x3, 0x181c080, 0xe, 0x0, 0x0, 0x0, 0x0, 0x57c078, ...)
/workdir/torizon/build-torizon/tmp-torizon/work/armv7at2hf-neon-tdx-linux-gnueabi/snapd/2.38-r0/build/src/github.com/snapcore/snapd/client/client.go:306 +0x7c fp=0x190fab8 sp=0x190fa68 pc=0x3cf67c
github.com/snapcore/snapd/client.(*Client).Change(0x18991f0, 0x1947e58, 0x2, 0x18991f0, 0x19b0000, 0x1947e58)
/workdir/torizon/build-torizon/tmp-torizon/work/armv7at2hf-neon-tdx-linux-gnueabi/snapd/2.38-r0/build/src/github.com/snapcore/snapd/client/change.go:84 +0xac fp=0x190faf8 sp=0x190fab8 pc=0x3cd888
main.waitMixin.wait(0x18991f0, 0x5f0000, 0x1947e58, 0x2, 0x0, 0x0, 0x0)
/workdir/torizon/build-torizon/tmp-torizon/work/armv7at2hf-neon-tdx-linux-gnueabi/snapd/2.38-r0/build/src/github.com/snapcore/snapd/cmd/snap/wait.go:88 +0x28c fp=0x190fc8c sp=0x190faf8 pc=0x4be448
main.(*cmdInstall).installOne(0x18c9590, 0xbebc4ed5, 0xb, 0x0, 0x0, 0x1994720, 0x582850, 0x5d2090)
/workdir/torizon/build-torizon/tmp-torizon/work/armv7at2hf-neon-tdx-linux-gnueabi/snapd/2.38-r0/build/src/github.com/snapcore/snapd/cmd/snap/cmd_snap_op.go:445 +0x254 fp=0x190fcf8 sp=0x190fc8c pc=0x4a7160
main.(*cmdInstall).Execute(0x18c9590, 0x18a1640, 0x0, 0x2, 0x18c9590, 0x1)
/workdir/torizon/build-torizon/tmp-torizon/work/armv7at2hf-neon-tdx-linux-gnueabi/snapd/2.38-r0/build/src/github.com/snapcore/snapd/cmd/snap/cmd_snap_op.go:548 +0x394 fp=0x190fd44 sp=0x190fcf8 pc=0x4a7ff0
github.com/snapcore/snapd/vendor/github.com/jessevdk/go-flags.(*Parser).ParseArgs(0x197a680, 0x1884108, 0x2, 0x3, 0xe8d18, 0x147, 0xa89758, 0xb6eee3ec, 0x0)
/workdir/torizon/build-torizon/tmp-torizon/work/armv7at2hf-neon-tdx-linux-gnueabi/snapd/2.38-r0/build/src/github.com/snapcore/snapd/vendor/github.com/jessevdk/go-flags/parser.go:333 +0x63c fp=0x190fe1c sp=0x190fd44 pc=0x114e28
github.com/snapcore/snapd/vendor/github.com/jessevdk/go-flags.(*Parser).Parse(...)
/workdir/torizon/build-torizon/tmp-torizon/work/armv7at2hf-neon-tdx-linux-gnueabi/snapd/2.38-r0/build/src/github.com/snapcore/snapd/vendor/github.com/jessevdk/go-flags/parser.go:190
main.run(0x1947040, 0xe)
/workdir/torizon/build-torizon/tmp-torizon/work/armv7at2hf-neon-tdx-linux-gnueabi/snapd/2.38-r0/build/src/github.com/snapcore/snapd/cmd/snap/main.go:481 +0x7c fp=0x190fed0 sp=0x190fe1c pc=0x4bce90
main.main()
/workdir/torizon/build-torizon/tmp-torizon/work/armv7at2hf-neon-tdx-linux-gnueabi/snapd/2.38-r0/build/src/github.com/snapcore/snapd/cmd/snap/main.go:448 +0x2b0 fp=0x190ffb8 sp=0x190fed0 pc=0x4bc978
runtime.main()
/usr/lib/go/src/runtime/proc.go:203 +0x208 fp=0x190ffe4 sp=0x190ffb8 pc=0x46950
runtime.goexit()
/usr/lib/go/src/runtime/asm_arm.s:857 +0x4 fp=0x190ffe4 sp=0x190ffe4 pc=0x737f0
goroutine 24 [syscall]:
os/signal.signal_recv(0x0)
/usr/lib/go/src/runtime/sigqueue.go:147 +0x130
os/signal.loop()
/usr/lib/go/src/os/signal/signal_unix.go:23 +0x14
created by os/signal.Notify.func1
/usr/lib/go/src/os/signal/signal.go:127 +0x34
goroutine 22 [IO wait]:
internal/poll.runtime_pollWait(0xa644df30, 0x72, 0xffffffff)
/usr/lib/go/src/runtime/netpoll.go:203 +0x44
internal/poll.(*pollDesc).wait(0x19ba1f4, 0x72, 0x1000, 0x1000, 0xffffffff)
/usr/lib/go/src/internal/poll/fd_poll_runtime.go:87 +0x30
internal/poll.(*pollDesc).waitRead(...)
/usr/lib/go/src/internal/poll/fd_poll_runtime.go:92
internal/poll.(*FD).Read(0x19ba1e0, 0x1973000, 0x1000, 0x1000, 0x0, 0x0, 0x0)
/usr/lib/go/src/internal/poll/fd_unix.go:169 +0x174
net.(*netFD).Read(0x19ba1e0, 0x1973000, 0x1000, 0x1000, 0x182a574, 0x70640, 0x18000e0)
/usr/lib/go/src/net/fd_unix.go:202 +0x38
net.(*conn).Read(0x199ac78, 0x1973000, 0x1000, 0x1000, 0x0, 0x0, 0x0)
/usr/lib/go/src/net/net.go:184 +0x64
net/http.(*persistConn).Read(0x1938140, 0x1973000, 0x1000, 0x1000, 0x18816c0, 0x393aec, 0x18816c0)
/usr/lib/go/src/net/http/transport.go:1825 +0x168
bufio.(*Reader).fill(0x1994810)
/usr/lib/go/src/bufio/bufio.go:100 +0x108
bufio.(*Reader).Peek(0x1994810, 0x1, 0x0, 0x0, 0x1, 0x1881600, 0x0)
/usr/lib/go/src/bufio/bufio.go:138 +0x38
net/http.(*persistConn).readLoop(0x1938140)
/usr/lib/go/src/net/http/transport.go:1978 +0x15c
created by net/http.(*Transport).dialConn
/usr/lib/go/src/net/http/transport.go:1647 +0x9b8
goroutine 23 [select]:
net/http.(*persistConn).writeLoop(0x1938140)
/usr/lib/go/src/net/http/transport.go:2277 +0xc4
/usr/lib/go/src/net/http/transport.go:1648 +0x9d4
goroutine 3 [runnable]:
main.waitMixin.wait.func1(0x19bc300, 0x18991f0, 0x19b0000, 0x1947e58, 0x2)
/workdir/torizon/build-torizon/tmp-torizon/work/armv7at2hf-neon-tdx-linux-gnueabi/snapd/2.38-r0/build/src/github.com/snapcore/snapd/cmd/snap/wait.go:61
created by main.waitMixin.wait
/workdir/torizon/build-torizon/tmp-torizon/work/armv7at2hf-neon-tdx-linux-gnueabi/snapd/2.38-r0/build/src/github.com/snapcore/snapd/cmd/snap/wait.go:61 +0xf0
trap 0x6
error 0x0
oldmask 0x0
r0 0x5aa50
r1 0x0
r2 0x24000000
r3 0x72
r4 0x1
r5 0x400
r6 0x181c0a0
r7 0xa3dfcbb8
r8 0x180c0a0
r9 0xa4f00b7f
r10 0x1800b60
fp 0xa4f00780
ip 0xa4f00780
sp 0xa3dfcb94
lr 0xa6432624
pc 0x5a49c
cpsr 0xa0070030
fault 0xe4
