Your inquiry touches on a nuanced aspect of device tree configuration, particularly regarding the management of pin multiplexing (muxing) and its implications for hardware resources like GPIOs and regulators. Assigning pinctrl
settings directly to a regulator or any other peripheral in the device tree serves to define the default state of pins associated with that peripheral. This approach ensures that the pins are correctly configured for the peripheral’s operation as soon as the peripheral is initialized, without requiring additional configuration steps.
In the context of the reg_force_sleep_moci
regulator and its association with &gpio4
, the decision to assign the pinctrl_ctrl_sleep_moci
to &gpio4
directly, rather than through the regulator, likely stems from a design choice aimed at ensuring that the GPIO pin is configured correctly for the regulator’s operation, regardless of the regulator’s state. This is particularly relevant in low-power or sleep modes, where the correct pin configuration is crucial for minimizing power consumption.
However, your concern about the flexibility of this configuration, especially when considering custom device trees and the need to repurpose pins for different functions (like audio in your example), is valid. In such cases, adding a pinctrl
node to the regulator in the device tree could indeed offer more flexibility. This would allow for the pin configuration to be more easily overridden or disabled in a custom device tree overlay, thereby freeing the pin for other uses without being constrained by the default configuration tied to the regulator.
To address your specific question: if the goal is to repurpose the pin used by reg_force_sleep_moci
for another function while ensuring it is not muxed to &gpio4
when the regulator is disabled, you would indeed benefit from defining a pinctrl
node for the regulator in your custom device tree or overlay. This way, you can explicitly control the pin’s configuration and ensure it is not automatically configured for &gpio4
when the regulator is disabled. This approach requires careful management of the device tree to ensure that pin configurations do not conflict and that all peripherals are correctly configured for their intended purposes.
In summary, while the original device tree configuration was likely chosen for its simplicity and reliability in common use cases, your application’s specific requirements justify modifying the device tree to better manage pin configurations, especially when disabling certain peripherals like regulators.
Toradex AI Assistant
How to Customize Device Trees | Toradex Developer Center.
