SGTL5000: Not enforcing symmetric_rates due to race
hello,
We have written one application in which we have created two pipeline i.e transmitter and receiver pipeline for audio . both the pipeline are not working simultaneously in the same process . At time only
one pipeline is working , when we are playing both the pipeline using thread then I am getting warning as
follows:
I also checked by running the command arecord | aplay I am getting same above error
Please help us to solve this problem , it is very critical for our customer.
Alok
Hi @alok
Welcome to Toradex community
Could you provide software and hardware versions of your setup?
what exactly you’re trying? recording and playing same time?
Hardware - Apalis T30 Module on Apalis Evaluation kit.
Software : Linux apalis-t30 3.1.10
Basically, we are implementing full duplex on it. So, it
should transmit and receive at same time. It is like a
Recording and playing at same time.
If you run following command on apalis t30 , you will see same warning :
arecord | aplay.
Please give us feedback as soon as possible.
Please give us feedback as soon possible
Hi @alok,
I checked with gstreamer pipeline earlier with Apalis imx6 module and it worked fine.
gst-launch-1.0 alsasrc device=“hw:0,0” ! audioconvert ! audioresample ! audio/x-raw, rate=48000 ! alsasink device=“hw:0,0”.I never tried with t30,let me check and update you.
Thanks for your response.
Have you checked following command on imx6 module :
arecord | aplay
Is it working fine? Pls update as soon as possible.
Alok
`Hi @alok
yes,it is working.
Can you quickly check with the below command and let me know
arecord -D hw:0,0 -V mono -c 2 -f S16_LE -r 48000 | aplay -D hw:0,0
