Hello again,
i am trying to reset/set the date of my device via U-boot.
I found the Manual of all Uboot commands here:
However when i look in the U-Boot console in the help command i only get this list:
Apalis iMX8 # help
? - alias for ‘help’
askenv - get environment variables from stdin
base - print or set address offset
bdinfo - print Board Info structure
blkcache - block cache diagnostics and control
bmp - manipulate BMP image data
boot - boot default, i.e., run ‘bootcmd’
bootaux - Start auxiliary core
bootd - boot default, i.e., run ‘bootcmd’
bootefi - Boots an EFI payload from memory
bootelf - Boot from an ELF image in memory
booti - boot Linux kernel ‘Image’ format from memory
bootm - boot application image from memory
bootp - boot image via network using BOOTP/TFTP protocol
bootvx - Boot vxWorks from an ELF image
cfgblock - Toradex config block handling commands
check_fips_mode- Display the FIPS mode of the SoC by reading fuse 0xA, bit 3
clk - CLK sub-system
cmp - memory compare
coninfo - print console devices and information
cp - memory copy
cpu - display information about CPUs
crc32 - checksum calculation
dcache - enable or disable data cache
dhcp - boot image via network using DHCP/TFTP protocol
dm - Driver model low level access
echo - echo args to console
editenv - edit environment variable
env - environment handling commands
exit - exit script
ext2load - load binary file from a Ext2 filesystem
ext2ls - list files in a directory (default /)
ext4load - load binary file from a Ext4 filesystem
ext4ls - list files in a directory (default /)
ext4size - determine a file’s size
ext4write - create a file in the root directory
false - do nothing, unsuccessfully
fastboot - run as a fastboot usb or udp device
fatinfo - print information about filesystem
fatload - load binary file from a dos filesystem
fatls - list files in a directory (default /)
fatmkdir - create a directory
fatrm - delete a file
fatsize - determine a file’s size
fatwrite - write file into a dos filesystem
fdt - flattened device tree utility commands
fstype - Look up a filesystem type
fuse - Fuse sub-system
go - start application at address ‘addr’
gpio - query and control gpio pins
gpio_conf - gpio configuration
gpt - GUID Partition Table
guid - GUID - generate Globally Unique Identifier based on random UUID
gzwrite - unzip and write memory to block device
hdp - load hdmi firmware
hdprx - load hdmi rx firmware
help - print command description/usage
i2c - I2C sub-system
icache - enable or disable instruction cache
iminfo - print header information for application image
imxtract - extract a part of a multi-image
itest - return true/false on integer compare
lcdputs - print string on video framebuffer
ln - Create a symbolic link
load - load binary file from a filesystem
loadb - load binary file over serial line (kermit mode)
loads - load S-Record file over serial line
loadx - load binary file over serial line (xmodem mode)
loady - load binary file over serial line (ymodem mode)
loop - infinite loop on address range
lzmadec - lzma uncompress a memory region
md - memory display
mdio - MDIO utility commands
mii - MII utility commands
mm - memory modify (auto-incrementing address)
mmc - MMC sub system
mmcinfo - display MMC info
mtest - simple RAM read/write test
mw - memory write (fill)
nfs - boot image via network using NFS protocol
nm - memory modify (constant address)
part - disk partition related commands
pci - list and access PCI Configuration Space
ping - send ICMP ECHO_REQUEST to network host
pinmux - show pin-controller muxing
printenv - print environment variables
pxe - commands to get and boot from pxe files
random - fill memory with random pattern
reset - Perform RESET of the CPU
run - run commands in an environment variable
save - save file to a filesystem
saveenv - save environment variables to persistent storage
scsi - SCSI sub-system
scsiboot - boot from SCSI device
scu_rm - scu partition function
select_dt_from_module_version-set_fips_mode- Set FIPS mode
setcurs - set cursor position within screen
setenv - set environment variables
setexpr - set environment variable as the result of eval expression
showvar - print local hushshell variables
sleep - delay execution for some time
snvs_cfg - Security violation configuration
snvs_clear_status- snvs clear status
snvs_dgo_cfg- SNVS DGO configuration
snvs_sec_status- tamper pin configuration
source - run script from memory
sysboot - command to get and boot from syslinux files
tamper_pin_cfg- tamper pin configuration
test - minimal test like /bin/sh
tftpboot - boot image via network using TFTP protocol
true - do nothing, successfully
ums - Use the UMS [USB Mass Storage]
unzip - unzip a memory region
usb - USB sub-system
usbboot - boot from USB device
uuid - UUID - generate random Universally Unique Identifier
version - print monitor, compiler and linker version
Where the date method is missing. I would prefer to not cook my own uboot version. Is there no way to set the date with the standard torizon uboot?
