Sdhci-tegra Internal Error on Apalis T30 and V2.6
Hi all,
I have remarked, that the sdhci-driver print this Errors in my kernel-log:
[   37.503320] sdhci-tegra sdhci-tegra.0: Internal clock never stabilised
[   37.548128] sdhci-tegra sdhci-tegra.0: Internal clock never stabilised
[   37.579281] sdhci-tegra sdhci-tegra.0: Internal clock never stabilised
[   37.642314] sdhci-tegra sdhci-tegra.0: Internal clock never stabilised
[   60.943058] sdhci-tegra sdhci-tegra.2: Internal clock never stabilised
[   60.987088] sdhci-tegra sdhci-tegra.2: Internal clock never stabilised
[   61.017799] sdhci-tegra sdhci-tegra.2: Internal clock never stabilised
[   61.078345] sdhci-tegra sdhci-tegra.2: Internal clock never stabilised
Hase any one this Error? or i am the only one.
My Hardware is based on Rev. 1.1A Apalis T30
Please help ;-(
I really did double check lots of internal log data on our full validation & verification as well as customer reports and did not find any trace of such an issue ever happening before. If this really does happen running our stock BSP demo image I suggest for you to initiate an RMA on the failing units and we will have a closer look at this issue.
Many thanks for your report. I have
found the Reason for this problem. we
have designed our Hardware for the
Apalis t30 with Specific requirment
and the Pin (SD1_CD#) was floating.
polling it up to 3,3V with 10k solve
that problem.
Many thanks again.
Abderrahim
