SDCard Insertion make Linux crash
I’m working on:
  • iMX7D
  • linux-toradex_4.1.15
  • angstrom-lxde-image-V2.6.1
Linux is capable of running without any problem for hours… But when I insert an SDCard, the Linux is completely blocked (no more prompt and screen blocked!)
The last trace are:
[   43.582946] mmc0: new high speed SDHC card at address b368
[   43.590801] mmcblk0: mmc0:b368 USD   7.37 GiB
[   43.599188]  mmcblk0: p1
Issue is systematic
What file system are you using on the SD-card (Partition 1)?
If you have a module version V1.1B or later, can you reproduce the issue using V2.7?
The file system on the SD Card is fat32. After I reboot the board and stop the boot, I able to use it to update the system.
My module is iMX7D 512MB V1.1C. I update repository to the V2.7… compiling is sooooo long
So, with version 2.7, it seems to work. But version 2.7 seems to be only beta… safe to use?
Hm, I cannot reproduce that here.
Maybe it is related to card detect GPIO… What Carrier Board are you using?
