Saphymo
1
Hello Toradex Team,
I have the following problem:
If I have no SD or HDMI connected when starting the Colibri T30 and I connect it later, then this is not recognized.
Only after restarting the SD card or HDMI is detected.
How can I remove this feature?
Many Thanks.
Best regards
Saphymo
Can you please provide some details about the carrier board:
do you use our standard Colibri Evaluation Board?
If not, can you please provide us some details about the circuits on your hardware, especially
- The HotPlug pin
- DDC
- SD Card Card-Detect
Did you change any registry values?
