After build TorizonCore from source, I want to run the system on qemu, but runqemu show me nothing in my terminal. Why?
user@ubuntu:~/work$ runqemu wic serial
runqemu - INFO - Running bitbake -e ...
runqemu - INFO - Continuing with the following parameters:
MACHINE: [qemuarm64]
FSTYPE: [wic]
ROOTFS: [/home/user/work/build-torizon/deploy/images/qemuarm64/torizon-core-podman-qemuarm64-20220315063214.rootfs.wic]
CONFFILE: [/home/user/work/build-torizon/deploy/images/qemuarm64/torizon-core-podman-qemuarm64-20220315063214.qemuboot.conf]
runqemu - INFO - Setting up tap interface under sudo
runqemu - INFO - Network configuration: ip=192.168.7.2::192.168.7.1:255.255.255.0
runqemu - INFO - Interrupt character is '^]'
runqemu - INFO - Running /home/user/work/build-torizon/tmp/work/x86_64-linux/qemu-helper-native/1.0-r1/recipe-sysroot-native/usr/bin/qemu-system-aarch64 -device virtio-net-device,netdev=net0,mac=52:54:00:12:34:02 -netdev tap,id=net0,ifname=tap0,script=no,downscript=no -drive if=virtio,file=/home/user/work/build-torizon/deploy/images/qemuarm64/torizon-core-podman-qemuarm64-20220315063214.rootfs.wic,format=raw -no-reboot -show-cursor -device VGA,edid=on -device qemu-xhci -device usb-tablet -device usb-kbd -object rng-random,filename=/dev/urandom,id=rng0 -device virtio-rng-pci,rng=rng0 -no-acpi -bios /home/user/work/build-torizon/deploy/images/qemuarm64/u-boot.bin -d unimp -semihosting-config enable,target=native -machine virt -cpu cortex-a57 -m 1057 -serial mon:vc -device virtio-serial-device -chardev null,id=virtcon -device virtconsole,chardev=virtcon
