Running TensorFlow Lite on NPU: Need Guidance
Hi, Iโ€™m the Toradex AI Assistant. The Toradex Support team will follow up with you shortly!
To run TensorFlow Lite on the NPU instead of the CPU, you need to ensure that your setup supports NPU execution and that the necessary drivers and configurations are in place. Here are some general steps you might consider:
  1. Verify NPU Support: Ensure that your hardware (e.g., i.MX8 series) supports NPU execution and that the TensorFlow Lite version you are using is compatible with NPU acceleration.
  2. Install NPU Drivers: The Dockerfile snippet you provided installs GPU drivers, but you need to ensure that NPU drivers are also installed. Check if there are specific NPU drivers or libraries required for your SoC and install them.
  3. Use the Correct TensorFlow Lite Delegate: TensorFlow Lite uses delegates to offload computation to hardware accelerators like NPUs. Ensure that you are using the appropriate delegate for NPU execution. This might involve setting up the TensorFlow Lite interpreter to use the NPU delegate.
  4. Modify Your Dockerfile: If there are specific packages or libraries required for NPU support, make sure to include them in your Dockerfile. This might involve adding additional packages or configuration steps.
  5. Check Documentation: Refer to the NXPโ€™s i.MX Machine Learning Userโ€™s Guide or any specific documentation related to NPU support for your hardware. This documentation might provide specific instructions or configurations needed to enable NPU execution.
  6. Test and Debug: After making the necessary changes, test your setup to ensure that TensorFlow Lite is executing on the NPU. You might need to debug and adjust configurations based on the results.
If you have access to specific documentation or support resources from NXP or Toradex, they might provide more detailed guidance tailored to your hardware and software setup.
NPU versus CPU Results and Training for Tensorflow lite - NXP Community.
