Dear Toradex:
We have noticed that the RTC on Viola plus 1.2A is not working and not storing the time and date.
The effect is reproducible
With the battery inserted for first time, some boards give us this message:
[ 1.101197] rtc-ds1307 0-0068: rtc core: registered m41t00 as rtc0
[ 1.111920] snvs_rtc 400a7034.snvs-rtc-lp: rtc core: registered 400a7034.snvs-rtc-l as rtc1
[ 2.299854] rtc-ds1307 0-0068: setting system clock to 2001-01-01 00:01:07 UTC (978307267)
Other boards give us the following:
[ 1.101118] rtc-ds1307 0-0068: rtc core: registered m41t00 as rtc0
[ 1.111837] snvs_rtc 400a7034.snvs-rtc-lp: rtc core: registered 400a7034.snvs-rtc-l as rtc1
[ 2.217886] rtc-ds1307 0-0068: hctosys: unable to read the hardware clock
With the system date synchronized, we put it onto the hardware clock with hwclock -w
root@zic-5110:~# hwclock -c
hw-time system-time freq-offset-ppm tick
978308238 1502459601.401509
978308250 1502459613.402800 108 1
978308261 1502459624.406764 228 2
978308272 1502459635.404667 93 1
978308283 1502459646.405208 82 1
1502459656 1502459656.496427 -1000000 -10000
1502459667 1502459667.496238 -1000000 -10000
1502459678 1502459678.496018 -1000000 -10000
Now the rtc has the correct time, if we unplugg the carrier board from the power supply, wait ten minutes (or less) and then power on the board, the dmesg shows the following:
[ 1.101457] rtc-ds1307 0-0068: rtc core: registered m41t00 as rtc0
[ 1.112199] snvs_rtc 400a7034.snvs-rtc-lp: rtc core: registered 400a7034.snvs-rtc-l as rtc1
[ 2.306225] rtc-ds1307 0-0068: setting system clock to 2001-01-01 00:02:09 UTC (978307329)
Showing that the RTC has reset to the default value, we tested this with several types of batteries:
Panasonic BR1225
Maxell CR1216
Maxell CR1220
with identical results.
Worse things happens on some boards when when we disconnect the power and reconnect it within five seconds, the boot process gets stucks with systemd messages:
[ 2.642635] random: systemd urandom read with 42 bits of entropy available
[ 2.665832] systemd[1]: systemd 215 running in system mode. (+PAM +AUDIT +SELINUX +IMA +SYSVINIT +LIBCRYPTSETUP +GCRYPT +ACL +XZ -SECCOMP -APPARMOR)
[ 2.690365] systemd[1]: Detected architecture 'arm'.
[ 2.727011] systemd[1]: Set hostname to <RTT74>.
[ 3.268849] systemd[1]: Cannot add dependency job for unit display-manager.service, ignoring: Unit display-manager.service failed to load: No such file or directory.
[ 3.305644] systemd[1]: Time has been changed
[ 3.314881] systemd[1]: Time has been changed
[ 3.323865] systemd[1]: Time has been changed
[ 3.332812] systemd[1]: Time has been changed
[ 3.341702] systemd[1]: Time has been changed
[ 3.350463] systemd[1]: Time has been changed
[ 3.359054] systemd[1]: Time has been changed
[ 3.367431] systemd[1]: Time has been changed
[ 3.375633] systemd[1]: Time has been changed
[ 3.383597] systemd[1]: Time has been changed
[ 3.391403] systemd[1]: Time has been changed
[ 3.399144] systemd[1]: Time has been changed
[ 3.406672] systemd[1]: Time has been changed
If we disconnect the power for ten minutes it boots again…
It appears to be a kernel bug, is there an update of the linux kernel? any workarround?
thanks
