After upgrading ToradexCELibraries from v2.1 to v2.2 I found a strange behavior that I can’t explain.
First of all, Rpmsg_Demo sample works as expected and this made the investigation much more difficult, unfortunately.
If I build my custom application both in Debug and in Release, I copy it on the module and I run it using Autorun/Autocopy feature, everything is ok.
But if I try to debug the same application from VS2008, Rpmsg_Init()
fails with message
Unhandled exception at 0x0018549c in MyApplication.exe: 0xC0000005: Access violation.
If I run from VS2008 the same application built in Release mode, it works.
Is it possible the library can have problems if the debugger is attached?
I don’t know if this helps, but my application creates two additional threads before calling Rpmsg_Init()
Rpmsg_Demo sample works when the debugger is attached.
Could you help me with this strange behavior?
Do you need some other information from my side?
