The Debian-based torizon containers have been very useful to customers: they let us develop our product quickly on Torizon OS 7.
However, as we prepare for the EU Cyber Resilience Act (full obligations from December 2027), we don’t think we can keep using chromium-imx8 and weston-imx8 in production in their current form. We have to inventory everything we ship, monitor it for known vulnerabilities and fix what we can. We have already moved our own containers to minimal, non-root images, and these two are what we have left.
We scanned the current arm64 images with state-of-the-art tools. Counts are CVE + source package pairs. They are raw scanner output, without analysis of whether each CVE is exploitable, and they may include some false matches because the packages carry +toradex versions.
| Image | Size | Debian packages | CVEs | Critical / High | Critical or High with a fix available | Listed in CISA KEV |
torizon/chromium-imx8:4.22.0 |
987 MB | 270 | 4688 | 478 / 2047 | 2329 | 23 |
torizon/weston-imx8:4.22.0 |
873 MB | 321 | 706 | 58 / 260 | 3 | 1 |
Chromium weak points
- Old browser version: the image ships
117.0.5938.132-2+toradex1, from September 2023. Almost all the fixable findings are in Chromium itself, so they can only be fixed by a newer browser, and any scan-based release gate will keep failing. - No sandbox:
start-chromium.shpasses--no-sandboxand--disable-seccomp-filter-sandbox, and the documented setup usesseccomp:unconfined. An old browser engine therefore runs without its main containment. - Extra packages: the image includes tools a production kiosk doesn’t need, such as
sudo,wget,apt,mesa-utilsand LLVM. - Debian base: it is still on bookworm, which is now in Debian LTS.
Weston weak points
- Attack surface: the image includes
libfreerdp,libneatvnc,xwayland,libavcodecand related libraries, GStreamer, PipeWire,sudo,wgetandapt. A simple kiosk compositor on HDMI needs few of these, and removing them later doesn’t help because they stay in the base layers. - Startup as root:
entry.shstarts as root and needs bash and Perl before it drops to thetorizonuser, which rules out a shell-less, non-root image. - Debian base and GPU stack: it is also on bookworm, and tied to
imx-gpu-viv-wayland6.4.11.p2.8. Because that driver is proprietary, we also have no CVE data for it.
My questions
- Is there a roadmap for a newer Chromium with GPU acceleration on iMX8M Plus? If so, which version and when? How often do you plan to update it?
- Do you plan to move the containers to Debian trixie? (already asked months ago)
- Do you plan smaller production variants?
- Can Weston run from a non-root start, with an explicit list of the devices and capabilities it needs?
If you need more details, we can share in private the full scan reports or test preview images on our boards.
Thank you for your help.
