Hi
I tried this by NFS booting with our V2.7 image and installing parted from the angstrom feeds.
One try was successful, one ended also in a segmentation fault, e.g.:
root@colibri-imx6:~# umount /dev/mmcblk0p2
root@colibri-imx6:~# fsck.ext3 /dev/mmcblk0p2
e2fsck 1.43 (17-May-2016)
rootfs contains a file system with errors, check forced.
rootfs: 23117/192640 files (2.7% non-contiguous), 127020/885760 blocks
root@colibri-imx6:~# resize2fs /dev/mmcblk0p2 900M
resize2fs 1.43 (17-May-2016)
Resizing the filesystem on /dev/mmcblk0p2 to 230400 (4k) blocks.
Segmentation fault (core dumped)
After upgrading to e2fsprogs 1.43.4 in openembedded-core which includes the patch Stefan referenced the resizing worked. e.g:
[layers/openembedded-core]$ git cherry-pick 8b9668c b51bb93
And rebuilding the image.
Then with NFS (or initramfs boot):
root@colibri-imx6:~# e2fsck -f /dev/mmcblk0p2
resize2fs 1.43.3 (04-Sep-2016)
The filesystem on /dev/mmcblk0p2 is now 230400 (4k) blocks long.
root@colibri-imx6:~# parted /dev/mmcblk0
GNU Parted 3.2
Using /dev/mmcblk0
Welcome to GNU Parted! Type 'help' to view a list of commands.
(parted) p
Model: MMC 004GE0 (sd/mmc)
Disk /dev/mmcblk0: 3959MB
Sector size (logical/physical): 512B/512B
Partition Table: msdos
Disk Flags:
Number Start End Size Type File system Flags
1 4194kB 21.0MB 16.8MB primary fat16 lba
2 21.0MB 3649MB 3628MB primary ext3
(parted) resizepart 2 1200MB
Warning: Shrinking a partition can cause data loss, are you sure you want to
continue?
Yes/No? Yes
(parted) mkpart p ext3 1200MB 3800MB
Warning: The resulting partition is not properly aligned for best performance.
Ignore/Cancel? i
(parted) print
Disk Flags:
2 21.0MB 1200MB 1179MB primary ext3
3 1200MB 3800MB 2600MB primary ext3 lba
(parted) q
Information: You may need to update /etc/fstab.
root@colibri-imx6:~# mkfs.ext3 /dev/mmcblk0p3
mke2fs 1.43 (17-May-2016)
/dev/mmcblk0p3 contains `zlib compressed data' data
Proceed anyway? (y,n) y
Discarding device blocks: done
Creating filesystem with 634765 4k blocks and 158720 inodes
Filesystem UUID: 494e2c56-cbd6-4c7b-8ded-88d7ae4e92c8
Superblock backups stored on blocks:
32768, 98304, 163840, 229376, 294912
Allocating group tables: done
Writing inode tables: done
Creating journal (16384 blocks): done
Writing superblocks and filesystem accounting information: done
After a reboot with the rootfs from the eMMC:
root@colibri-imx6:~# df
Filesystem 1K-blocks Used Available Use% Mounted on
/dev/root 891352 442844 434204 50% /
/dev/mmcblk0p1 16334 4942 11392 30% /media/mmcblk0p1
/dev/mmcblk0p3 2433636 3788 2302896 0% /media/mmcblk0p3
tmpfs 50964 0 50964 0% /run/user/0
