Hello Prem0919,
Thank you for your question! I understand you want to ensure that all code and data for the Cortex-M7 are placed in ITCM and DTCM on the Verdin iMX8M Plus for the best performance.
Below is a template for a GNU ld (linker script) file that will place your code (.text), read-only data (.rodata), initialized data (.data), and zero-initialized data (.bss) into the appropriate TCM regions:
/* Verdin iMX8M Plus M7 TCM linker script example */
/* ITCM: 128KB at 0x00000000 - 0x0001FFFF (for code) */
/* DTCM: 128KB at 0x20000000 - 0x2001FFFF (for data) */
MEMORY
ITCM (rx) : ORIGIN = 0x00000000, LENGTH = 128K
DTCM (rwx) : ORIGIN = 0x20000000, LENGTH = 128K
SECTIONS
/* Place code and read-only data in ITCM */
.text :
KEEP(*(.isr_vector))
*(.text*)
*(.rodata*)
*(.glue_7)
*(.glue_7t)
*(.eh_frame*)
} > ITCM
/* Initialized data in DTCM */
.data : AT(__data_load_addr)
__data_start__ = .;
*(.data*)
. = ALIGN(4);
__data_end__ = .;
} > DTCM
__data_load_addr = LOADADDR(.data);
/* Uninitialized data (BSS) in DTCM */
.bss (NOLOAD) :
__bss_start__ = .;
*(.bss*)
*(COMMON)
. = ALIGN(4);
__bss_end__ = .;
} > DTCM
/* Stack can also be allocated in DTCM if required */
__StackTop = ORIGIN(DTCM) + LENGTH(DTCM);
__StackLimit = __StackTop - 0x400; /* Example: 1KB stack */
/* ... other sections as necessary ... */
/* Provide symbols for startup code */
PROVIDE(__stack = __StackTop);
Notes:
- Modify sizes if your application is getting close to the 128KB limits.
- Make sure your startup (crt0) code copies the .data section from flash/ROM/load address to DTCM at startup.
- The actual section labels (.text, .data, .bss) should match what is used by your toolchain/startup code.
For more details regarding addresses, refer to the memory regions described here:
It is also advisable to review MCUXpresso SDK examples for the i.MX8MP, as they include linker scripts tailored for this platform:
Let me know if you need further clarification or help customizing the script for your project!
