When IMX6ULL is powered on , there is no output on the serial console.So i put the board into recovery mode by following the link : iMX Recovery Mode | Toradex Developer Center .
The board boots up , and i use tftp/nfs to load kernel and rootfs.
1 . I follow the link : Colibri iMX7 Firmware Update - Technical Support - Toradex Community ,
to update the u-boot , there are no errors displayed. But , on restarting the board does not boot.
2. The same is the case when i use the ‘run setupdate’ , ‘run update’ commands from u-boot.The steps are a success on restart it does not boot.
3. The same happens when i update the u-boot-nand.imx from the u-boot.
Please let me know if i any additional steps need to be taken care of.
Thank you for the reply.So, i am now trying to replace the whole image via Toradex Easy Installer. As i do not have the easy installer in my board, i download the image from ‘Load Toardex Easy Installer’ section and run recovery-linux.sh on my linux-PC (while the board is in recovery mode). It boots up (i can check in my serial console).
I do not have a display, so i can connect via vncviewer, for which i require an IP, according to the TEZI the IP is ‘192.168.11.1’, which i should be able to check by running the command ‘ip addr show eth0’ (I have USB/otg cable plugged in to the otg port of the board).
But when i run the command in the serial console i do not see the IP address.
Hence unable to connect via vncviewer.
Could you please let me know about what i might be missing.
The interface of RNDIS is called usb0. You can check this with ifconfig. eth0 is the Ethernet Interface which needs Ethernet connection and a proper network setup.
But when i run the command in the serial console i do not see the IP address. Hence unable to connect via vncviewer. Could you please let me know about what i might be missing.
Did you try to connect to the Ip address 192.168.11.1?
yes, i forgot to mention , but i checked with ifconfig as well. I tried connecting to 192.168.11.1 via vncviewer, but it does not connect.
ifconfig does not show usb0.
U-Boot 2016.11-1.8.0+g07edca0bb8 (Oct 19 2018 - 13:34:09 +0000)
CPU: Freescale i.MX6ULL rev1.1 792 MHz (running at 396 MHz)
CPU: Industrial temperature grade (-40C to 105C) at 44C
Reset cause: POR
DRAM: 512 MiB
NAND: 512 MiB
MMC: FSL_SDHC: 0
Using default environment
Video: 640x480x18
In: serial
Out: serial
Err: serial
MISSING TORADEX CONFIG BLOCK
Model: Toradex Colibri iMX6ULL
Serial Downloader recovery mode, using sdp command
Net: FEC0
SDP: initialize...
SDP: handle requests...
Downloading file of size 20856020 to 0x82100000... done
Downloading file of size 237 to 0x82000000... done
Jumping to header at 0x82000000
Header Tag is not a IMX image
## Loading kernel from FIT Image at 82100000 ...
Using 'config@1' configuration
Trying 'kernel@1' kernel subimage
Description: Linux Kernel 4.1
Type: Kernel Image
Compression: uncompressed
Data Start: 0x821000e0
Data Size: 4887376 Bytes = 4.7 MiB
Architecture: ARM
OS: Linux
Load Address: 0x81000000
Entry Point: 0x81000000
Hash algo: md5
Hash value: 5b8a3fa97134f80a06ee830c58e75dcf
Verifying Hash Integrity ... md5+ OK
## Loading ramdisk from FIT Image at 82100000 ...
Trying 'ramdisk@1' ramdisk subimage
Description: SquashFS RAMdisk
Type: RAMDisk Image
Data Start: 0x825a9518
Data Size: 15929344 Bytes = 15.2 MiB
Architecture: ARM
OS: Linux
Load Address: unavailable
Entry Point: unavailable
Hash algo: md5
Hash value: fff196a3409547b7ed2046bf9081b3ff
## Loading fdt from FIT Image at 82100000 ...
Trying 'fdt@1' fdt subimage
Description: Colibri iMX6ULL Device Tree
Type: Flat Device Tree
Data Start: 0x834da5e4
Data Size: 37816 Bytes = 36.9 KiB
Architecture: ARM
Hash algo: md5
Hash value: f61ffa470f6c279d7fade885b5600b74
Booting using the fdt blob at 0x834da5e4
Loading Kernel Image ... OK
Loading Device Tree to 8fff3000, end 8ffff3b7 ... OK
Updating MTD partitions...
Starting kernel ...
[ 0.540602] gpmi-nand 1806000.gpmi-nand: mode:5 ,failed in set feature.
[ 0.588059] imx_usb 2184000.usb: Can't register ci_hdrc platform device, err7
Running /etc/rc.local...
Colibri-iMX6ULL_ToradexEasyInstaller_1.8-20181019
Welcome to Toradex Easy Installer
This is a Linux based installer for Toradex modules. Currently the
installer does not have a serial console interface. You can use the
Toradex Easy Installer through any of the available display interfaces
using USB mouse/keyboard or via network using VNC. Use:
# ip addr show eth0
to display the Ethernet IP address or use USB RNDIS at IP 192.168.11.1.
/ # ifconfig
eth0 Link encap:Ethernet HWaddr 00:14:2D:00:00:00
UP BROADCAST MULTICAST MTU:1500 Metric:1
RX packets:0 errors:0 dropped:0 overruns:0 frame:0
TX packets:0 errors:0 dropped:0 overruns:0 carrier:0
collisions:0 txqueuelen:1000
RX bytes:0 (0.0 B) TX bytes:0 (0.0 B)
/ # lsusb
Bus 001 Device 001: ID 1d6b:0002
You can place a TEZI compatible image to USB flash or SD card and change autoinstall value to true at json file. Than insert this media to your carrier board.and load TEZI. TEZI will automatically flash that image. Please check for more details here.
Could you please let me know the format for the image/folder layout in USB flash?
I downloaded ‘Toradex Embedded Linux Images’ for Colibri IMX6ULL under the ‘OS and demo images tab’ and extracted it to my USB flash.Then I run the TEZI (with autoinstall changed to true in image.json), but its the same output as mentioned above.
I could not find any information related to this.
Format your USB media as FAT32 and unpack this file to a root. Then change a “autoinstall”: false, to “autoinstall”: true,
at /Colibri-iMX6ULL_Console-Image-Tezi_2.8b6.184/image.json
Yes, I believe the MISSING TORADEX CONFIG BLOCK is the culprit. In this case, one would need to recover it first which is usually done using the Toradex Easy Installer GUI. Alternatively, one could try doing this in U-Boot using its cfgblock create command. After that any- and everything should work as usual again (;-p).
