There is a clean registry binary file cleanreg.bin
from imx6_wince7image-tezi_1.2-20170719
. The content of this file is 0x58 0x58 0x58 0x58
. What kind of tool should one use to generate registry binary file if customized registry file is needed?
To create a custom registry file:
Apply all the registry settings to a clean module
Backup the registry using the UpdateTool (let’s call the file
MyRegistry.bin
Modify the Toradex-Easy-Installer configuration file
image.json
as below.
Please note, the second copy of the registry must remain clean.…
“filename”: “MyRegistry.bin”,
“dd_options”: “seek=2”
“filename”: “cleanreg.bin”,
“dd_options”: “seek=16386”
Update Tool can backup registry in i6r format instead of bin. Is it okay just rename it from backup.i6r to backup.bin ?
