I follow the directions to enter recovery mode on iMX8 with Aster carrier board. This involves shorting two pads with a screwdriver while powering up. Get a blank screen (had to remove USB during power up, else would always boot into some broken desktop that is non-functional).
However, when using a macOS as host, when execute recover-linux.sh get this error:
I don’t think you’ll be able to use the recovery script on Mac because of the uuu being a Linux binary.
Can you try again using a Linux machine?
Just a little consideration for your test with Linux, is that we do not recommend using it in a Virtual-Machine, as USB enumeration can change during the recovery process, and the VM can lose the USB assignment.
Thanks, I moved to an ubuntu machine, and got this:
sean@dev2:~/Documents/Colibri-iMX8X_ToradexEasyInstaller_2.0b6-20201102$ ./recovery-linux.sh
Downloading Toradex Easy Installer…
[sudo] password for sean:
uuu (Universal Update Utility) for nxp imx chips – libuuu_1.4.43-0-ga9c099a
Success 0 Failure 0 Wait for Known USB Device Appear…
When power on, get a black screen… but the card is never detected…
did lsusb and saw that the card is seen by USB:
sean@dev2:~$ sudo lsusb
Bus 006 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
Bus 005 Device 002: ID 046d:c52b Logitech, Inc. Unifying Receiver
Bus 005 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Bus 004 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
Bus 003 Device 007: ID 0403:6001 Future Technology Devices International, Ltd FT232 USB-Serial (UART) IC
After about 5min, the linux boot sequence starts, and ends up with blank gray screen:
