After starting up the Toradex installer in recovery mode, is there any way to escape the recovery mode and come back to normal mode? I am using ixora v1.2A carrier board and imx8 quadmax
hello which module you are using exactly?
imx8 quadmax
Hello Mohar,
if I understand you right, your board got stuck in the recovery mode?
Can you try to recover it to the Toradex Easy Installer. and then press the install button. And after install unpower the board and disconnect USB OTG.
And see if it is booting into tezi?
Matthias
