Can you confirm if these messages appear as soon as you reboot the board again?
I saw some references to this issue here and here.
From the second link: It look likes the Ubi error only appears in the first time the board boots after reflash (run update && run setupdate). If after the first time I reboot the board and try to git clone on the second time linux boots it works.
Of course, this is a surprise, and we expected it do not appear. But judging by an ubifs developer feedback on the 1st link, it seems to be inoffensive.
I saw that your original post was targeting BSP 2.8. I hope you don’t be mad about my suggestion, but I really suggest you move forward to BSP 3.0.4, because is our current LTS with a lot of improvements, bug fixes, etc…
The BSP 2.8b7 is only for production devices receiving security updates.
For newer products, BSP 3.0.4 is strongly recommended.
Thanks for the links!.. Slightly encouraging that one of the links mentioned its not a concern…
These messages only appear once after mender reboots when it finishes re-flashing an update. Actually we are using BSP 3.0.4b.
…but there will always be some worry unless it can be solved (or fully understood). What if in a year or two the NAND can’t be updated and we have bricked units in the field - this kind of recall can bring down a company.
