Qt4e-demo-image on VF50 is to large. How can I adjust manually?
hello dear support team,
I have a colibri VF50 and would like to run a qt application on it ( Qt Creator to cross compile - Embedded Linux ) .
I have entered the following commands (Ubuntu 16.04):
sudo apt install build-essential -y
sudo apt install qt4-default qtcreator -y
sudo dpkg --add-architecture i386
sudo apt-get update
sudo apt-get install g++-5-multilib -y
sudo apt-get install curl dosfstools gawk g++-multilib gcc-multilib lib32z1-dev libcrypto++9v5:i386 libcrypto++-dev:i386 liblzo2-dev:i386 lzop libsdl1.2-dev libstdc++-5-dev:i386 libusb-1.0-0:i386 libusb-1.0-0-dev:i386 uuid-dev:i386 texinfo chrpath git -y
cd /usr/lib; sudo ln -s libcrypto++.so.9.0.0 libcryptopp.so.6
cd ~
mkdir ~/bin
export PATH=~/bin:$PATH
curl http://commondatastorage.googleapis.com/git-repo-downloads/repo > ~/bin/repo
chmod a+x ~/bin/repo
git config --global user.name "XXX"
git config --global user.email XXX
mkdir oe-core
cd oe-core
repo init -u http://git.toradex.com/toradex-bsp-platform.git -b LinuxImageV2.8
repo sync
. export
nano conf/local.conf
    select: MACHINE ?= "colibri-vf"
    add: ACCEPT_FSL_EULA = "1"
cd ~/oe-core
. export
bitbake -k qt4e-demo-image
bitbake -k meta-toolchain-qte
../deploy/sdk/angstrom-glibc-x86_64-armv7at2hf-vfp-neon-toolchain-qte-v2014.12.sh
. /usr/local/oecore-x86_64/environment-setup-armv7at2hf-neon-angstrom-linux-gnueabi
echo $OE_QMAKE_CXX
/usr/local/oecore-x86_64/sysroots/x86_64-angstromsdk-linux/usr/bin/qt5/qmake
qtcreator
i have flashed the image on a SD-card und put it into my colibri-evaluation board with colibri VF50.
run setupdate
run upate
flashing always stuck at “reading colibri_vf/ubifs.img”.
Of course, I also tried the following:
nand erase.part ubi
i know that the image is to large for VF50 ( Flashing Colibri VF50 - Toradex Community )
How can i adjust the image manually e.g. by removing packages/features ???
best regards
stsemant
hi @stsemant
Could you provide the software version of your module?
Unfortunately, I do not know exactly what you mean by software version of the module, so I write everything that comes to mind:
# U-Boot 2016.11-2.8.6+g83a53c1
# LinuxImageV2.8
# backports-kernel-module ... colibri_vf 4.19-r0
# kernel-module ... colibri_vf 4.4+git0+6f01eb5bf8-r0
# qt4-embedded ... armv7ahf-neon 4.8.7-r0
# util-linux ... armv7at2hf-neon 2.30-r0
Hi
Thanks for the information. Actually you can check the software version with ( uname -a )?
I would suggest you to use build the console image and just add the packages you need for QT.
That way, I can not verify the software version of the qt4e-demo-image because the VF50 gets stuck in the boot process.
May I like to use the console-image ( console-tdx-image ) and add the QT packages I need.
Can you please tell me how to add these QT packages before creating the image? And which packages do I need for QT4 and which packages QT5?
Sure, you can do this?
You need to edit the local.conf and add the following line with the package you want to include in the image:
IMAGE_INSTALL_append = " qt-package-to-install"
You can find the QT4 packages here and the Qt5 packages are at this link and build a console image.
Alternatively you can also build an angstrom-qt-x11-image or an angstrom-qt5-x11-image
Yes, I’m sure I can. After all, you said that to me:
:wink:
Thank you very much. Now I know which packages are there and how to add them. But which packages do I need to get a QT application running on a Colibri VF50?
By the way, the angstrom-qt-x11-image, just like the qt4e-demo-image, is too large for the vf50 module. After the command “run update” it gets stuck with the message “reading colibri_vf/ubifs.img”
That’s true. Alternatively you can put the image on a SD and boot from there as explained here.
Depending on your requirement, you can also buy a module with larger flash size.
Thanks for the hint, that was very helpful!
I packed the demo with the wic-package on an SD card and started the VF50 with the command from the SD-Card. Furthermore, I ordered the VF61, so that there the demo completely fits.
Perfect that the solution with SD card worked. Thanks for the feedback.
