Qt text invisible with console-tdx-image
When I run my program on my custom ‘console-tdx-image’ all text is invisible. after search I found that I should install fontconfig.
How can I install it?
dmesg file
Hi @jaski.tx
I added dmesg log
Could you provide the software version of your module?
Apalis-iMX6_Console-Image 2.8b4
What exactly is your program?
it’s a QWidget with only QPushButton on it.
Which graphical interface are you using?
I use eglfs.
The solution was useful.
Thanks.
Hi @prog
What exactly is your program? Which graphical interface are you using?
Concerning fontconfig, you can add this to a custom image that you compile yourself.
