Did you make sure that you open the QtCreator in the same console as you sourced your environment with . /usr/local/oecore-x86_64/environment-setup-armv7at2hf-neon-angstrom-linux-gnueabi?
Yes, I did.
You can also check if the environment is setup properly by hitting echo $OE_QMAKE_CXX, this should print you some details about your toolchain. Does this work and what does it print?
yes, it work’s. it print’s:
arm-angstrom-linux-gnueabi-g++ -march=armv7-a -mthumb -mfpu=neon -mfloat-abi=hard --sysroot=/usr/local/oecore-x86_64/sysroots/armv7at2hf-neon-angstrom-linux-gnueabi
after enter “qtcreator” in the same command line, it starts qtcreator with the info in the command line:
void DBusMenuExporterPrivate::addAction(QAction*, int): Already tracking action "Follow Symbol Under Cursor" under id 173
This is all done on your host machine, right? Beside that, did you install the related image on the VF61?
Yes, I did.
Here are the screenshots you want:
[upload|7/knt6hvlTfAD9NYMI8Ol/h6m6M=]
[upload|BokBvGiIOs3iqD9nB7bOMLunL/w=]
[upload|QzU91J+0HDkYfmuR9ZLq9pYv43o=]
[upload|U7rcBaOnoa0lC0L8thpx+WFrvWQ=]
[upload|eRkYtAulhMkPaGqXN0sapYViPec=]
