I just installed a Linux V2.6.1 image and environment on my 32 bit OpenSuse Linux 13.1 desktop.
Then I built Qt SDK ($ bitbake - k meta-toolchain-qt5)
and Qt target image ($ bitbake -k angstrom-lxde_image) patched in …/local/local.conf with IMAGE_INSTALL_append = “qtbase qtbase-fonts qtbase-plugins cinematicexperience”.
Then I installed SDK (./deploy/sdk/angstrom-glibc-armv7at2hf-v2015.12-toolchain.sh -S)
When in oe-core directory, after issuing . /usr/local/oe-core-i686/environment-setup-armv72hf-vfp-angstrom-linux-gnueabi, I can run qtcreator , bat Qt installation seems to be spoilt.
Devices: Local PC.
Build & Run - Kit Unnamed-GCC (x86 32 bit in /usr/bin)2
Build & Run - Qt versions
Version name Qt 4.8.5 (System) (marked with !)
qmake location: /usr/local/oecore-i686/sysroots/i686-angstromsdk-linux/usr/bin/qmake2
Qt version is not properly installed, please run make install
Qt version 4.8.5 for Desktop: The Qt version is invalid : Qt version is not properly installed, please run make install.
It is not possible to compile any project even for the PC environment.
Truly I cannot figure out how to solve this situation; please help.
Thank you for your attention.
Miguelon.
