Trying to configure qspi on Colibri imx7d (NAND)
I include the imx7d-sdb-qspi.dtsi to imx7d-colibri-eval-v3.dts which should declare the pinctrl.
But while booting the kernel i get :
imx7d-pinctrl 30330000.iomuxc: no fsl,pins and pins property in node /soc/aips-bus@30000000/iomuxc@30330000/qspi1
[ 1.638236] imx7d-pinctrl 30330000.iomuxc: invalid function qspi1 in map table
[ 1.645530] fsl-quadspi: probe of 30bb0000.spi failed with error -22
The aips-bus address is the aips1 address not the aips3
Onn the module filesystem /sys/firmware/devicetree/base/soc/aips-bus@30800000/spi@30bb0000 exists and the aips address is aips3 - which should be correct.
