Hi Pramod,
Based on the information provided, it seems like your Python logger configuration is causing an issue when running on the Verdin iMX8MM board. Here are a few steps to troubleshoot and resolve the issue:
Check Python Version: Ensure that the Python version on your Verdin iMX8MM board is compatible with the version you used during development. You can check the Python version by running:
python --version -
File System Permissions: Verify that the directory where you are trying to create the log file (
app.log) has the necessary write permissions. You can check and modify permissions using:ls -l /path/to/directory chmod +w /path/to/directory -
Encoding Issues: Ensure that the file encoding is consistent. Sometimes, encoding issues can cause problems when running scripts on different systems.
Syntax Error in Logging Configuration: There seems to be a syntax issue in your logging configuration. The quotes used in the
formatparameter are not standard single quotes. Replace them with standard single quotes ('). Also, the**name**should be__name__. Here is the corrected code:import logging # Basic configuration logging.basicConfig(level=logging.DEBUG, format='%(asctime)s - %(name)s - %(levelname)s - %(message)s', filename='app.log', filemode='w') # Create a logger logger = logging.getLogger(__name__) -
Dependencies: Ensure that all necessary Python packages are installed on the Verdin iMX8MM board. You can install required packages using pip:
pip install -r requirements.txt -
Run the Script Manually: Try running the script manually on the Verdin iMX8MM board to see if it provides more detailed error messages:
python your_script.py
If the issue persists after these steps, please provide the exact error message you are encountering, and any additional context that might help in diagnosing the problem.
[Your Name]
