Hi there,
Hardware:
Colibri iMX6DL
with Viola Carrier Board Rev 1.2
TorizonCore 5.7.2
Python 3.10 installed
I’m just checking to see if anyone has come across a python error while using a Docker container and build everything inside that container, i.e. Windows 11 + WSL (v2)…
Running the command…
$ docker run --rm -it --name=crops -v ~/yocto-workdir:/workdir --workdir=/workdir -e MACHINE=colibri-imx6 -e IMAGE=[torizon-core-docker](https://github.com/toradex/meta-toradex-torizon/blob/dunfell-5.x.y/recipes-images/images/torizon-core-docker.bb) torizon/crops:dunfell-5.x.y startup-tdx.sh
reports the following output…
Build environment configured. Building target image torizon-core-docker
DISTRO=torizon-upstream MACHINE=colibri-imx6 bitbake torizon-core-docker
Loading cache: 100% |###########################################################################| Time: 0:00:00
Loaded 3850 entries from dependency cache.
Build Configuration:
BB_VERSION = "1.46.0"
BUILD_SYS = "x86_64-linux"
NATIVELSBSTRING = "universal"
TARGET_SYS = "arm-tdx-linux-gnueabi"
MACHINE = "colibri-imx6"
DISTRO = "torizon-upstream"
DISTRO_VERSION = "5.7.3-devel-20230725201321+build.0"
TUNE_FEATURES = "arm armv7a vfp thumb neon callconvention-hard"
TARGET_FPU = "hard"
meta-toradex-torizon = "HEAD:478c84ed5ea78b87bbe0e79c88aac6e8bf3c1c84"
meta-toradex-distro = "HEAD:53f241006b8cf69c31c22ce27e837261156ddae8"
meta-toradex-bsp-common = "HEAD:f88e4c50e64ca144a7a15bd50c92a13d325f6780"
meta-oe
meta-networking
meta-filesystems
meta-python
meta-perl = "HEAD:b5282ece919f016d91a1043769676efb02b4f0fb"
meta-virtualization = "HEAD:beea119eb529b4a11f266004aee8b548427aea39"
meta-updater = "HEAD:8e02177c2d9fa416f3117c5da1c0dfba7709dfbf"
meta-toradex-nxp = "HEAD:8797f291ca2d9c8e0b2efedf37bf3bd10709ee81"
meta-freescale = "HEAD:f66fdef1c2dc735690a7ec7dd44a534d69ea3918"
meta-freescale-3rdparty = "HEAD:4c0a166fa2809f74c93bd4c56d9a0f7ccb7818c8"
meta-yocto-bsp
meta-poky = "HEAD:5faf10f83e45aceb3d14c904346d82ea3ce9bdcc"
meta-security = "HEAD:c62970fda82acf75035243766ecd195243e0f82a"
meta = "HEAD:b3fc8ef9aba822b3d485242c8ebd0e0bff0ebfc8"
Initialising tasks: 100% |######################################################################| Time: 0:00:06
Sstate summary: Wanted 1010 Found 136 Missed 874 Current 1118 (13% match, 58% complete)
NOTE: Executing Tasks
WARNING: linux-toradex-mainline-5.4.193+gitAUTOINC+cf62fa8fd9_f5d73fd6e9-r0 do_package: KeyError in ./package
ERROR: linux-toradex-mainline-5.4.193+gitAUTOINC+cf62fa8fd9_f5d73fd6e9-r0 do_package: Error executing a python function in exec_func_python() autogenerated:
The stack trace of python calls that resulted in this exception/failure was:
File: 'exec_func_python() autogenerated', lineno: 2, function: <module>
0001:
*** 0002:sstate_report_unihash(d)
0003:
File: '/workdir/torizon/build-torizon-upstream/conf/../../layers/openembedded-core/meta/classes/sstate.bbclass', lineno: 875, function: sstate_report_unihash
0871: report_unihash = getattr(bb.parse.siggen, 'report_unihash', None)
0872:
0873: if report_unihash:
0874: ss = sstate_state_fromvars(d)
*** 0875: report_unihash(os.getcwd(), ss['task'], d)
0876:}
0877:
0878:#
0879:# Shell function to decompress and prepare a package for installation
File: '/workdir/torizon/layers/openembedded-core/bitbake/lib/bb/siggen.py', lineno: 555, function: report_unihash
0551:
0552: if "." in self.method:
0553: (module, method) = self.method.rsplit('.', 1)
0554: locs['method'] = getattr(importlib.import_module(module), method)
*** 0555: outhash = bb.utils.better_eval('method(path, sigfile, task, d)', locs)
0556: else:
0557: outhash = bb.utils.better_eval(self.method + '(path, sigfile, task, d)', locs)
0558:
0559: try:
File: '/workdir/torizon/layers/openembedded-core/bitbake/lib/bb/utils.py', lineno: 421, function: better_eval
0417: if extraglobals:
0418: ctx = copy.copy(ctx)
0419: for g in extraglobals:
0420: ctx[g] = extraglobals[g]
*** 0421: return eval(source, ctx, locals)
0422:
0423:@contextmanager
0424:def fileslocked(files, *args, **kwargs):
0425: """Context manager for locking and unlocking file locks."""
File: '<string>', lineno: 1, function: <module>
File "<string>", line 1, in <module>
File: '/workdir/torizon/build-torizon-upstream/conf/../../layers/openembedded-core/meta/lib/oe/sstatesig.py', lineno: 595, function: OEOuthashBasic
0591:
0592: update_hash("\n")
0593:
0594: # Process this directory and all its child files
*** 0595: process(root)
0596: for f in files:
0597: if f == 'fixmepath':
0598: continue
0599: process(os.path.join(root, f))
File: '/workdir/torizon/build-torizon-upstream/conf/../../layers/openembedded-core/meta/lib/oe/sstatesig.py', lineno: 559, function: process
0555: except KeyError as e:
0556: bb.warn("KeyError in %s" % path)
0557: msg = ("KeyError: %s\nPath %s is owned by uid %d, gid %d, which doesn't match "
0558: "any user/group on target. This may be due to host contamination." % (e, path, s.st_uid, s.st_gid))
*** 0559: raise Exception(msg).with_traceback(e.__traceback__)
0560:
0561: if include_timestamps:
0562: update_hash(" %10d" % s.st_mtime)
0563:
File: '/workdir/torizon/build-torizon-upstream/conf/../../layers/openembedded-core/meta/lib/oe/sstatesig.py', lineno: 553, function: process
0549: add_perm(stat.S_IXOTH, 'x')
0550:
0551: if include_owners:
0552: try:
*** 0553: update_hash(" %10s" % pwd.getpwuid(s.st_uid).pw_name)
0554: update_hash(" %10s" % grp.getgrgid(s.st_gid).gr_name)
Exception: Exception: KeyError: 'getpwuid(): uid not found: 1000'
Path ./package is owned by uid 1000, gid 1000, which doesn't match any user/group on target. This may be due to host contamination.
ERROR: Logfile of failure stored in: /workdir/torizon/build-torizon-upstream/tmp/work/colibri_imx6-tdx-linux-gnueabi/linux-toradex-mainline/5.4.193+gitAUTOINC+cf62fa8fd9_f5d73fd6e9-r0/temp/log.do_package.413
ERROR: Task (/workdir/torizon/build-torizon-upstream/conf/../../layers/meta-toradex-bsp-common/recipes-kernel/linux/linux-toradex-mainline_5.4.bb:do_package) failed with exit code '1'
NOTE: Tasks Summary: Attempted 3181 tasks of which 3022 didn't need to be rerun and 1 failed.
NOTE: Writing buildhistory
NOTE: Writing buildhistory took: 2 seconds
Summary: 1 task failed:
Summary: There was 1 WARNING message shown.
Summary: There was 1 ERROR message shown, returning a non-zero exit code.
pokyuser@c80ef7096946:/workdir/torizon/build-torizon-upstream$
It looks like the getpwuid() method is causing an error as part of the linux-toradex-mainline-5.4.193+gitAUTOINC+cf62fa8fd9_f5d73fd6e9-r0 process.
Let me know if you have any suggestions.
Many Thanks Jon
