Hello Julián,
To address the issue you’re encountering with integrating the PulseAudio equalizer into your Yocto-based system, please follow these steps:
Install FFTW3 Development Package: Ensure that the FFTW3 development package is included in your Yocto build environment. You can do this by adding the following line to your
local.conf:IMAGE_INSTALL:append = " fftw3" -
Verify pkgconfig Setup: Check that the
pkgconfigfor FFTW3 is correctly set up. Make sure thefftw3f.pcfile is present in yourPKG_CONFIG_PATH. This file is essential for the build system to locate the FFTW3 library. -
Modify pulseaudio.inc: Confirm that your modification to enable FFTW in
pulseaudio.incis correct. The line should be:EXTRA_OEMESON += "-Dfftw=enabled"Ensure there are no syntax errors and that this change is applied during the build process.
Clean and Rebuild: After making these changes, perform a clean build of the PulseAudio package to ensure all configurations are applied correctly. Use the following commands:
bitbake -c clean pulseaudio bitbake pulseaudio
By following these steps, you should be able to resolve the dependency issue and successfully generate the image with the PulseAudio equalizer.
Toradex AI Assistant
