I planing to provisioning a bunch of Apalis TK1s. Most of them are fresh modules so the should boot directly into TEZI.
But for some modules that already have an image flashed onto them, I am trying to find a mechanism to flash a freshed new image with as little interaction as possible.
Looking around I found this. It seems I can run TEZI from u-boot using the command run distro_bootcmd
I tried this, I made a FAT32 USB Drive and copied boot.scr and tezi.itb into it. I also added image I wanted to be flashed in https://docs.toradex.com/104854-apalis-tk1-linux-lxde-image-beta-tezi.tar. Unzipped into USB root.
I booted the TK1 into u-boot and ran run distro_bootcmd
I got the following output.
Scanning usb 0:1...
e1000: no NVM
e1000: e1000#0: ERROR: Valid Link not detected: -8
missing environment variable: pxeuuid
missing environment variable: bootfile
Retrieving file: pxelinux.cfg/01-00-14-2d-2c-6e-5b
Retrieving file: pxelinux.cfg/C0A80A02
What am I doing wrong?
