Dear Toradex team and Toradex community,
Trying to compile/run the HelloWorld application on a colibri T20 with linux LXDE 2.8, an executable binary is generated but it won’t run.
We are using toolchain:
configured on CodeBlocks.
The build succeeds, see below:
-------------- Build: Debug in HelloWorld (compiler: GNU GCC Compiler for ARM)---------------
arm-angstrom-linux-gnueabi-g++ -Wall -fexceptions -g -std=c++11 -mfpu=vfpv3-d16 -march=armv7-a -mthumb -mfpu=vfp -mfloat-abi=hard -I/usr/local/oecore-x86_64/sysroots/armv7at2hf-vfp-angstrom-linux-gnueabi/usr/include/c++/7.3.0 -I/usr/local/oecore-x86_64/sysroots/armv7at2hf-vfp-angstrom-linux-gnueabi/usr/include/c++/7.3.0/arm-angstrom-linux-gnueabi/ -I/usr/local/oecore-x86_64/sysroots/armv7at2hf-vfp-angstrom-linux-gnueabi/usr/include -I/usr/local/oecore-x86_64/sysroots/armv7at2hf-vfp-angstrom-linux-gnueabi/usr/lib -c main.cpp -o obj/Debug/main.o --sysroot=/usr/local/oecore-x86_64/sysroots/armv7at2hf-neon-angstrom-linux-gnueabi
arm-angstrom-linux-gnueabi-g++ -o bin/Debug/HelloWorld obj/Debug/main.o --sysroot=/usr/local/oecore-x86_64/sysroots/armv7at2hf-vfp-angstrom-linux-gnueabi -Wl,-O1 -Wl,--hash-style=gnu -Wl,--as-needed -no-pie
Output file is bin/Debug/HelloWorld with size 31.41 KB
Process terminated with status 0 (0 minute(s), 0 second(s))
0 error(s), 0 warning(s) (0 minute(s), 0 second(s))
The flags we used are:
armv7-a
-mthumb
-mfpu=vfp
However, the output executable does not run.
Any ideas on what we are missing?
thank you in advance
