assemblato e collegato il tutto il sistema si è acceso regolarmente.
selezionata la versione linux demo stable ho iniziato l’installazione
Durante l’installazione il display si è spento e non c’è più stato modo di riaccenderlo
Dove ho sbagliato?
E’ possibile tornare alla configurazione di fabbrica e reiniziare la procedura di installazione?
Dear @Lucke_Hall
Welcome to the Toradex Community!
The language of this community is English. Could you write you question in English, please?
Thanks and best regards,
I assembled and connected the whole system turned on regularly.
I selected the linux demo stable version
I started the installation
During installation, the display turned off and there was no way to turn it on again.
What did I do wrong? Is it possible to go back to the factory configuration and restart the installation procedure?
Could you provide the version of the Software of the module?
You can follow up these instructions to put the module in recovery mode and reinstall the Bsp using Toradex Easy Installer.
For the display Setup, did you follow this guide?
