I’m trying to use torizoncore-builder images unpack, if I choose an image without multimedia ex: torizon-core-docker-verdin-imx8mp-Tezi_5.7.2+build.20.tar, everything is OK but If I choose an image with multimedia ex: Verdin-iMX8MP_Reference-Multimedia-Image-upstream-Tezi_6.2.0-devel-202303+build.9.tar I have this message:
<_io.TextIOWrapper name=‘/storage/tezi/image.json’ mode=‘r’ encoding=‘UTF-8’>
The problem is for all images with mulimedia.
Regards
Hi @FranckSimon !
As you can see from TorizonCore Builder documentation (below), it is meant only for TorizonCore images.
Multimedia is one of the Reference images and is not a TorizonCore image, as you can see e.g. from Toradex Download Links (Torizon, Yocto Project Reference Images, WinCE and Partner Demos) | Toradex Developer Center
hello @FranckSimon ,
Were you able to solve your issue with the info provided by @henrique.tx ? If so, could you please mask his answer as a solution?
Josep
