Hello! Thank you for providing detailed information about your setup and the issue you are experiencing.
Based on the error message and your description, it seems that there is a lingering configuration that still references the old IP address 10.21.38.123, which is causing trouble during Docker Compose operations. Let’s go through some troubleshooting steps:
- Check
settings.jsonin Your Project Directory
Ensure you have the correct host IP set in your project’s.vscode/settings.json:
"host_ip": "192.168.87.125"
If you find the old IP anywhere, replace it with your actual host or device IP.
Reference
- Check Docker Daemon Configuration on Your Colibri Board
On your Colibri iMX6, check the content of/etc/docker/daemon.json. It should have the correct registry address, like:
"insecure-registries" : ["192.168.87.125:5002"]
If you see the old IP here, update it accordingly.
Reference
- Check for Stale Docker Compose Configurations
Sometimes, old Docker Compose project data persists and tries to use outdated settings:
Run
docker ps -aanddocker network lson both your development PC and your Colibri board to look for any stopped containers or unused networks that reference the old IP. Remove anything suspicious. -
Clear any old
docker-composecontainers/networks with:docker compose -p torizon down -
On your development PC, ensure there are no hidden settings files or Docker configuration caches pointing to the old IP.
- Double-Check Network Access and Docker Settings
Since a new Hello World project works, the problem is likely in the configuration of your specific application or its Docker Compose file. Double check:
- That ports 2375 and 5002 are accessible from your PC to the Colibri board.
- The stability and correctness of your network setup (firewalls, routes, etc.).
- That you do not have environment variables like
DOCKER_HOSTpointing to the old IP, either globally or in your workspace configuration.
- Try Removing and Re-adding the Project
If the issue persists, create a fresh clone/copy of your project, and set up the Torizon IDE extension there from scratch. This can sometimes eliminate residual configuration artifacts.
If none of the above steps work, a systematic comparison of .vscode, Compose, and Docker-related files between your working Hello World and affected project may reveal the lingering reference.
Let me know if these steps help or if you need further assistance!
